Old 12-07-2004, 02:32 PM   #1
nytoy
Member#: 48962
2000 Impreza 2.5RS
Default Causes of CEL codes P0122 and P1133
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P1133 Front oxygen sensor heater circuit high input
I've searched, nothing specifically to help me on the TPS error.
What should I start doing to fix these? Previous owner said he replaced both 02 sensors and the 1133 code was off for a week before it came back on.
the car runs and drives good, it does buck a little around 3k rpm, and smells like unburnt fuel, plus getting 23mpg on the expressway.
mods:
Borla header, apexi n1 cat-back.
Cobb CAI, JUN 9lb flywheel
Any ideas?
nytoy is offline   Reply With Quote
Old 12-07-2004, 03:23 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
ya...definately sounds like somethign is going on with your O2 Sensor.
Did the prev. owner replace the front or the rear O2 Sensor? I dunno about the first TPS code though.
DDMan is offline   Reply With Quote
Old 12-08-2004, 12:30 PM   #3
nytoy
Member#: 48962
2000 Impreza 2.5RS
anyone else know the TPS?
Old 12-20-2004, 04:44 PM   #4
nytoy
Member#: 48962
2000 Impreza 2.5RS
tttt
Old 12-27-2004, 02:02 PM   #5
nytoy
Member#: 48962
2000 Impreza 2.5RS
help
Old 12-27-2004, 02:12 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Probably a bad TPS sensor. You can try unplugging the sensor (located on the throttle body) and plugging it back in, on the chance that it's just a bad connection. If that doesn't do it there is probably a "dead spot" in the TPS at the idle or just off-idle position where it sees the most action, that is how they usually fail. The TPS can be tested with an ohmeter or by connecting a scanner to the car that reads live data, and watching the readings (resistance or throttle %) as it is moved through its range. The readings should change in a linear fashion with no jumps or dropouts.
The 02 code could be a bad heater in the 02 itself, but if you've already replaced the sensor with a new one it could also be a wiring problem. Sometimes the wiring harness for the sensor can be damaged by heat if it gets too close to the exhaust or actually comes in contact with it.
causes of cel code p0442 CatfaceType-R AccessPort 8 11-26-2007 02:05 PM
I failed inspection because of CEL codes, where to go? jefersun Texas Impreza Club Forum -- TXIC 19 07-19-2006 10:44 PM
Cel codes p0122 and p0442 turbocolin Tri-State Area Forum 3 03-22-2005 09:00 PM
I got a couple of cel codes today. Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-23-2004 11:02 AM
What has been the cause of CEL on your WRX? malelee21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-27-2002 03:10 AM
