Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 12-16-2004, 08:55 AM   #51
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Cut the guy some slack Adrian. While engineering terms are engineering terms, 10dB higher or lower is twice as loud or quieter to the human ear. Don't get me started on what a 250dB active sonar transmission does to whales.
Old 12-16-2004, 09:06 AM   #52
SaabTuner
Member#: 67608
Awwww. That'd be really cool to hear about too.
I was just giving you guys a hard time anyway. Never take things too seriously! Aaaalways look on the bright side of life ... da na, da na da na da na ...
SaabTuner is offline   Reply With Quote
Old 12-16-2004, 06:39 PM   #53
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
http://hyperphysics.phy-astr.gsu.edu...und/db.html#c1
"Another consideration which prompts the use of powers of 10 for sound measurement is the rule of thumb for loudness: it takes about 10 times the intensity to sound twice as loud."
So there...
GLwagon is offline   Reply With Quote
Old 12-16-2004, 06:46 PM   #54
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
Originally Posted by LotusDrift
Sounds like a good test.
my next liscence plate is going to own *snickers*
Wow. My exhaust was up there at the 3krpm point! W00t W00t. Now, who wants to pay my exhaust ticket???
D_Block is offline   Reply With Quote
Old 12-16-2004, 06:47 PM   #55
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Touche! I sense an e-dork fight ruining this thread.
Old 12-16-2004, 07:29 PM   #56
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
Originally Posted by GravelRash
One note that I remember from some C&D(?) sound testing a few years back: the background for your "sound stage" can make a huge difference in the readings. E.g., car sitting on dirt with an open grassy field behind it would produce much lower readings than having the car sitting on concrete, in front of a concrete wall.
this is true, I would assume he is testing on asphalt or concrete (shouldn't make a difference) with no other cars/people, walls, etc in the immediate area. the lower the frequency tested the greater these distances need to be.
ptaaty is offline   Reply With Quote
Old 12-16-2004, 07:30 PM   #57
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
I will run my own test tomorrow when i finally go from stock exhaust to an APS 3" catless TBE and vishnu up.
Old 12-22-2004, 05:58 PM   #58
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Testing policy:
a. All measurement are and will be taken with an Exetech digital dB meter with an accuracy of plus or minus 2db using the same settings at the same distance.
b. All idle measurements are taken at warm idle, NOT cold (higher RPM) idle, and then 3000RPM.
c. All measurements are taken 6" from the tailpipe.
d. All measurements are averaged, not peak high or peak low as the exhaust dB can vary 5-10dB due to the boxer motor characteristics.
Ever consider doing the testing in a truly STANDARD fashion, such as the procedure laid out by the Society of Automotive Engineers in their spec for automotive exhaust noise testing?
SAE J1169
I'm surprised that you didn't search before you started doing this.
nhluhr is offline   Reply With Quote
Old 12-22-2004, 06:40 PM   #59
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I thought about it, but since my meter doesn't comply with ANS S1.4-1971 standards, there wouldn't be point would there? Aside from that nonesense, I correlated my data to match the results that Turbo Magazine got with their testing so that I could have more exhaust data.
If you are trying to view the data over the next day or three, my host got borked due a ton of people downloading a certain WRX video. I hope everything minus the video will be back online very soon.
Old 12-22-2004, 06:48 PM   #60
servingko
Member#: 58105
2004 WRX
Just a point of clarification relating to the "NOTES" section d. "3bB is equal to twice the loudness, so an exhaust at idle with 93dB is twice as loud as an exhaust at 90dB."
In point of fact, an increase of 10dB is required to obtain a "perceived" doubling of loudness. Much of this misconception has occured due to the fact the the energy required to increase the sound level will need to double for every 3dB increase. This holds true from approximately 40hz on up through the range of human hearing. As frequencies decrease, less energy is required to obtain a "perceived" doubling of loudness.
servingko is offline   Reply With Quote
Old 01-02-2005, 09:13 PM   #61
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Bump for two new exhausts. I did a CES full TBE on an STi and just a Greddy catback on an 05 WRX.
Old 01-16-2005, 10:09 PM   #62
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Added another Prodrive and Blitz dB tests to the spreadsheet.
Old 01-17-2005, 01:55 AM   #63
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
will this be sticky or will it take 10 years like everything else?
David Medina is offline   Reply With Quote
Old 01-17-2005, 02:03 AM   #64
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
It's referenced in my Exhaust FAQ. Since I'm a mod now, I can sticky it. I probably will later on down the road when I refurb the 2.0 stickys.
Old 01-17-2005, 03:07 AM   #65
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
you are hardcore. you have helped the masses, may god have a special place in heaven for you.
Old 02-06-2005, 10:54 AM   #66
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Another update with 8 exhausts/cars tested. I got to test a Borla Hush finally. Still not as quiet as my Prodrive.
Old 03-01-2005, 04:19 PM   #67
MrDestructo
Member#: 72518
2005 WRX STI
WR BLUE
Pardon me for asking, but I'm trying to make sense of the results.
There are two listings for the the Greddy Evo catback with everything else stock.
Line 16: 2002 WRX: idle 94, 3000rpm 92.
Line 52: 2005 WRX: idle 94, 3000rpm 102!!
Did something big change from 2002 to 2005 or is this a mistake???
Otherwise very useful info.
Anyone care to guess what a Helix UP, Bosal DP and Bosal ST Catback would rate on there? I'm looking for something that isn't as noisey @3000rpm as my current setup.
MrDestructo is offline   Reply With Quote
Old 03-01-2005, 10:59 PM   #68
zaxrex
Member#: 9898
Water Injected Blue
BTW, what is with the shipping & handling charge on the PayPal donation link? Am I going to be sent something?
zaxrex is offline   Reply With Quote
Old 03-01-2005, 11:14 PM   #69
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
As to the Greddy ECO test, I cannot say. I assume the #16 one was brand spanking new. The #52 one was a used one. I'd hypothesize that the older an exhaust is, the worse it gets in quieting sound.
As to the paypal link, I don't send anything and don't know why it has S&H charges. Perhaps I was drinking when I filled it out. Send if you want, but so far, I've made a whopping $1. I only put up the link as a joke mainly.
Old 03-01-2005, 11:20 PM   #70
crikreef
Member#: 69101
04 FXT
any chance of getting some data on Perrin exhaust? i've got catback right now on my 04 wrx, be happy to help you out if u ever in san diego area
crikreef is offline   Reply With Quote
Old 03-02-2005, 03:20 AM   #71
SaabTuner
Member#: 67608
Gets coated with carbon. My friends and I regularly wash our mufflers inside. I know I know ... corrosion. But what's the point in even having it if it doesn't muffle?
Here are two other concepts straight out of "The Scientific Design of Exhaust and Intake Systems" that might help you reach muffling goals:
1: Tri-Y headers, the technical name for which is "interference" headers, have a SIGNIFICANT muffling effect. The GP-Moto headers make a Stage II WRX with Stromung catback almost as quiet as a stock STi!
2: A "muffler to nowhere", which is a resonator pipe attached in parrallel to your exhaust which has no outlet can actually muffle sound significantly! Some mufflers for Rotary engines have them built into the muffler.
Just food for thought!
Adrian~
Old 03-02-2005, 12:54 PM   #72
zaxrex
Member#: 9898
Water Injected Blue
As per Paypal:
Item Amount:
$1.00 USD
Shipping:
$0.04 USD
Handling:
$0.00 USD
Quantity:
1
Item Title:
Helpin' a brother pay for his meter
Date:
Mar. 1, 2005
Time:
18:57:23 PST
Status:
Completed
And then they take $0.30 out of that for themselves.
Well, here is another drop in the bucket. Maybe if you make a covert trip up to NoVa, Darrin and I can get a chance to talk to you and play with the DB meeter (I'll make sure he chips in some as well).
Old 03-20-2005, 08:16 PM   #73
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Added 3 more entries from testing today in San Diego, an APS, a Helix, and a Stromung.
Old 03-21-2005, 12:29 AM   #74
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Hey Ron -
In your exhaust testing travels, did you ever take note of which muffler sections are straight -through and which are chambered?
snvin is offline   Reply With Quote
Old 03-21-2005, 01:13 AM   #75
pux888
Member#: 8356
02 STi swap
12 WRX limited
actually 6 dB spl is twice as loud.
pux888 is offline   Reply With Quote
Exhaust DB chart?? hangten93 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-25-2005 04:15 PM
I am now testing exhaust dB levels with teh accuracy! Unabomber Mid Atlantic Impreza Club -- MAIC 44 12-22-2004 03:54 PM
blitz nur spec exhaust db limit kokuryu1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-02-2003 08:14 AM
Exhaust dB measurements GLwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-01-2003 05:13 PM
exhaust db level idea? SkypatCorbin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-28-2002 04:28 PM
