Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 12-07-2004, 04:13 PM   #1
mcornale
Member#: 57449
07 Legacy spec B
Default vf 28, vf 30, vf 34
Which of the following turbo's would be the best to put into an 02 wrx?vf 28, vf30, vf 34. If you could explain why that would be great. Thanks for your help. (puting in access port, sti pinks, walbro fuel pump.) Want to try to run 12's no crazy amount of boost
mcornale is offline   Reply With Quote
Old 12-07-2004, 04:16 PM   #2
VisionaryRacing
Member#: 48794
2oo5 Impreza STi
www.visionaryracing.com
If you are going to be using a accessport you can only use the vf30 or 34. There is no map for the vf28. Out of the two choices, the vf34 spools up a bit quicker.
VisionaryRacing is offline   Reply With Quote
Old 12-07-2004, 04:24 PM   #3
mcornale
Member#: 57449
07 Legacy spec B
what about between a vf 22 and a vf 34 I herd the 22 isnt to reliable doesnt last to long
Old 12-07-2004, 04:43 PM   #4
b0dh1
Member#: 35269
2011 WRX
b0dh1 is offline   Reply With Quote
Old 12-07-2004, 04:58 PM   #5
InfamousDX
Member#: 25413
crosspostingisbad.com
vf 39 vs 30 and 34 drewwrxrogers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-29-2006 07:47 PM
vf 28, vf30, vf 34 mcornale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 12-10-2004 03:46 AM
vf-30 / vf-34 install rckdya Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-20-2003 05:49 PM
VF 30 / VF 34 Needed mantra1 Private 'Wanted' Classifieds 8 07-30-2003 06:32 PM
Are you guys using your heat shields after installing your VF-22, VF-30, VF-34 turbo? blitz01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-25-2003 11:04 PM
