Old 12-08-2004, 04:28 AM   #1
03 Black R3x
Member#: 63177
2003 WRX
Midnight Black Pearl
Default Where is this drain plug located?
Stupid question, but from the picture here, I can't tell where the drain plug is.
Can you be specific plz sorry like driverside near oil pan or by header by passenger side. I know it's kinda dumb but yea...thanks in advance
03 Black R3x is offline   Reply With Quote
Old 12-08-2004, 04:29 AM   #2
InfamousDX
Member#: 25413
On the bottom of the passenger side of the radiator.
Old 12-08-2004, 05:42 AM   #3
03 Black R3x
Member#: 63177
2003 WRX
thanks,
also I don't understand steps 8 and 9. can someone clarify this. what does the air bleeder hole look like and "radiator filler port to neck of filler" what is this...
I want ot try to change my own coolant so I just want to make sure I understand every step. I am a noob.
Old 12-08-2004, 05:57 AM   #4
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
as you should soon find out, it's not as hard as it seems.
SubieStyle is offline   Reply With Quote
Old 12-08-2004, 08:14 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Find a local area member with automotive mechanical knowlege to assist you.....
Old 12-08-2004, 09:02 AM   #6
ejh25
Member#: 65267
It is easy to get your hand on the plug but sometimes loosening it can be a PITA. It is plastic so be careful with it. You don't want to break it. If you do you will have to drain the coolant from the lower radiator hose which is messy messy messy.
The refilling part isn't that bad. Fill it up with as much coolant as it will take (remembering to do it slowly to minimize the amount of air in the coolant system. Then start the car and fill the coolant up until it won't take anymore. Put the cap back on and you should be set. You will want to periodically check your coolant levels for the next week or so. Also don't forget to flush the system and use the Subaru coolant conditioner.
ejh25 is offline   Reply With Quote
Old 12-08-2004, 01:39 PM   #7
Gethin
Member#: 2998
Also "burping" the hoses helps, by squeezing them to get the air out.
Gethin is offline   Reply With Quote
Old 12-08-2004, 02:28 PM   #8
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
oh and if you want to flush all of it pull the lower hose..
you can drain every ounce out that valve then pull the hose and a half gallon will still flood out and hit you in the face... even more if you remember to say to your friend.. "oh I don't need goggles I already drained the fluid"
MustGoFast is offline   Reply With Quote
Old 12-08-2004, 05:21 PM   #9
03 Black R3x
Member#: 63177
2003 WRX
thanks for all the help guys, gonna do it this weekend
Engine Block coolant drain plug location? Sir_Xenon Service & Maintenance 3 05-14-2004 11:43 AM
Where is the drain plug for the front differential for MY98 Legacy Outback? V6 Outback Forum 1 10-28-2003 09:03 AM
Where is the drain plug for the front differential for MY98 Outback and MY00 RS? V6 Transmission (AT/MT) & Driveline 3 10-07-2003 02:54 AM
newbie here, where is this life meet located? subiedoobiedoo Southern California Impreza Club Forum -- SCIC 19 06-19-2003 03:55 AM
Need a pic where the tranny drain plug is BIG BEN Transmission (AT/MT) & Driveline 3 11-02-2002 01:22 AM
