Old 07-03-2001, 02:50 AM   #1
nsotak
Member#: 3048
2008 OBS
Silver/Silver
Question G-tech hp for stock OBS?
I used my friends G-tech and need a baseline to see if I need to downsize my pipes from 2.25"-->2." Does anyone have some numbers from a stock exhausted OBS? Also include what weight you used and how heavy you are.
Thanks,
nick
nsotak is offline   Reply With Quote
Old 07-03-2001, 09:26 AM   #2
ChaosThom
Member#: 1507
2003 Tiburon
Rally Red
When mine was stock... I made runs at 3,000lbs and got inconsistant results ranging from 117 to 122. I weigh 165. Hope that helps.
ChaosThom is offline   Reply With Quote
Old 07-04-2001, 12:25 AM   #3
lars
Member#: 6736
2000 GT Limited
White Burch
What are you guys talking about?? Go get the car weighed. Why guess. Set the G-Tech at the correct weight, straight ahead on the windshield, and 0.0 sitting still. It will give you very consistent HP and is within 0.10 sec. in the 1/4 mile.
2000 GT Limited weight was exactly posted curb weight given by Subaru with all fluids full, dealer installed options, and driver = 3620 lbs.
If you cheat on the weight, go light, your HP will be down. If you tell G-Tech your heavier the HP will go up. Your only kidding yourself without the known weight of the car, I know because I made the same mistake your making.
Made 6 passes at 108 HP on the ground. Even by varying the weight (give or take) 10 lbs. and missing a shift during one run it still recorded 108HP.
Don't forget tire pressure, ambient temp., fuel tank level, and wind direction (avoid the head wind). Every test should be done exactly the same for best results.
lars is offline   Reply With Quote
Old 07-04-2001, 01:34 AM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default G-Tech Tested
I tested my OBS before my G-Tech Pro got stolen. At 3118lbs (Me included), I was getting anywhere from 106hp-111hp. I was averaging around 109hp most of the time. This is with an automatic if that means anything.
Why did I pick 3118lbs? This is what my car weight was at Englishtown Raceway after weighing over and over again during runs at events or street nights. It varied back and forth due to gas tank levels and junk in the car but it mainly was around this weight.
Kevin Thomas is offline   Reply With Quote
WTT/GC8 KG/MM springs for stock OBS springs marooned RS VIC Private Classifieds 0 03-29-2007 01:59 PM
tein h tech...good for stock struts? spooln407 Brakes, Steering & Suspension 25 07-15-2006 07:31 AM
WTT: Walbro 255 HP for Stock '04 STi Fuel Pump. incontrol Vancouver Impreza Club Forum -- VIC 2 05-07-2006 01:19 PM
TOO Much HP for Stock clutch VtecThisWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-05-2003 05:39 PM
Max HP for stock injectors? Giamilton Normally Aspirated with bolt-on Forced Induction Powertrain 21 01-04-2003 02:39 PM
