Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-08-2004, 12:59 PM   #1
Liam D
Member#: 50500
Default Need extensions for heater hose under seats
I'm putting my amps under the driver and passenger seats of my Forester, but the ductwork for the heater blows hot air straight onto them. Not exactly good for keeping them cool. I wanted to run some extension about 12" long for the hot air to pass over them w/o blowing on them.
It's tough to find the right size though, since it's pretty much a rectangular hose about 2 3/4"L x 3/4"H plastic hose. I only need about 4 feet of it, and the only thing I found that could work was at Lowe's and they wanted something ridiculous like $10/ft.
Any suggestions on where to find something like this? Dealer was no help, and a quick look on mcmaster.com didn't turn up anything.
Liam D is offline   Reply With Quote
Old 12-08-2004, 01:03 PM   #2
Boost-Free Subee
Member#: 61052
1999 2.5 RS
duct tape the ducts closed. screw the people in the rear. jk. the amount of heat from those ducts is probably cooler than an amp running hot, and will still cool the amp down. don't worry. (unless the amp has a crappy heatsink design)
Boost-Free Subee is offline   Reply With Quote
Old 12-08-2004, 01:17 PM   #3
Liam D
Member#: 50500
So what you're saying is for example: The amp is running @ 100*, and since the heater is only blowing say 80* on it, it's actually cooling it?
I suppose you're right, since after the interior warms up, the heater air T* is essentially the same as the surrounding cabin T*.
I hadn't thought of it that way. Thanks
Old 12-08-2004, 01:37 PM   #4
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
assuming that the hot air from the heater duct is cooler than the amp is kinda running after trouble. it is sure than you can extend those for cheap, finding some 1.5" tube and connect them with duct tape. something like an vaccum cleaner hose will do the job pretty well IMO
NicEJ25 is offline   Reply With Quote
Old 12-08-2004, 01:49 PM   #5
Boost-Free Subee
Member#: 61052
1999 2.5 RS
we've installed hundreds of amps under seats, and an amp's heat sink can get up to 150 F. easily. if you've got 150 F coming out of YOUR ducts, you've got more than just audio problems...
Old 12-08-2004, 02:32 PM   #6
Liam D
Member#: 50500
I hear you Boost, but if I could find some cheap hose to stick on there I'd like to. Key word there is CHEAP!
NicEJ25, the shape is weird as I said before, so just finding some hose is harder than it sounds. Any suggestions?
RCA Length Needed for HU to Under-Seat Amp KevlarSTi Car Audio, Video & Security 3 06-27-2009 10:34 AM
EGR heater hose extension = MELTED... What now?? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-16-2008 03:23 PM
WTB: armrest extension, compass/homelink mirror, under seat sub The_Urban_Knight Private 'Wanted' Classifieds 0 06-26-2005 12:02 AM
heater hose works for oil return line? WRX Jim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-19-2005 01:06 PM
heater hose ok for oil lines? TheWeis Service & Maintenance 3 07-28-2003 11:34 PM
