Old 12-08-2004, 03:00 PM   #1
F3nom3ni
Member#: 73250
2006 Evo IX
Widows Son
Default AP Question...
I just recieved my Cobb accessPORT. I am going to be running the 93 octane stage 2 map. I know it says I need my stock intake on there, but I already have an AEM CAI. Can I keep that on there or do I absolutely need to put my stock intake back on? Will the map be screwed up if I kept it on there?
If the answer is yes I have to take the CAI off, is there anything I can do to the stock intake to help air flow out a little more?
Thanks.
F3nom3ni is online now   Reply With Quote
Old 12-08-2004, 03:08 PM   #2
04 blue rex
Member#: 59494
2008 WRB STi
2009 FXT
You can get away with leaving the aftermarket intake on, you may lose a little with out the stock air box, but you should be fine. I have had my perrin intake with the AP for about 6 months with no problems, if the car runs funny switch the CAI out. You could even try it both ways for your own piece of mind, only takes a little while to swap between the two.
04 blue rex is offline   Reply With Quote
Old 12-08-2004, 03:13 PM   #3
F3nom3ni
Member#: 73250
2006 Evo IX
Widows Son
Okay.
Any more ideas anyone?
Old 12-08-2004, 03:20 PM   #4
logikbomb
Member#: 50399
2002 WRX Sedan
I think Cobb is coming out with a map for an intake in a while (read: a couple months). I'd take it out and just hang on to it until then.
logikbomb is offline   Reply With Quote
Old 12-08-2004, 03:25 PM   #5
MDRex
Member#: 38477
2011 WRX Hatch
Satin White Pearl
I'm running st2 with stock intake and it's great. My friend is running a stage 2 AccessECU with a Perrin short intake, bigger TMIC and lightened crank pulley, his car runs great and pulls harder than mine.
MDRex is offline   Reply With Quote
Old 12-08-2004, 04:34 PM   #6
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
Ive been thinking about getting the access port, but after reading the maps you have to have freaking stock everything. I have a TBexhaust minus the cat back... so what am I to do? Now I'm kind of hesitent to spend the money for one if it's not going to work right.
03twrx is offline   Reply With Quote
Old 12-08-2004, 04:40 PM   #7
hondaeater69
Member#: 60324
Thanks.
If you think you're "gaining" anything from that intake you're just kidding yourself to begin with. THe stock IS a CAI, AND it's designed properly. I would be hesitant to run an aftermarket intake unless I could monitor EGT's at a minimum, and better yet WB AFR's. If you have a TBE minus cat back (stock), you'll be good for stage 2.
Old 12-08-2004, 04:52 PM   #8
03twrx
Member#: 73737
Right, but I've read all the maps and they all require stock parts.... maby I read the maps for just stage 1.. I'm sure I missed something.
Old 12-08-2004, 05:05 PM   #9
hondaeater69
Member#: 60324
yea, you must have missed something.
I have a VF34 with MANY aftermarket parts on my car, and it runs like a champ (off the shelf mapping)!
Certain parts will "mess" with their generic tuning, and others will not. Read their website to find out which ones will and which will not.
Old 12-08-2004, 05:17 PM   #10
gjhsu
Member#: 12329
2oo7 R56 mcs
Blue, but not WRB
Those aren't requirements. More like suggestions. They made the maps with stock this-and-that, but it does allow for some variations without penalty of death. It's definitely worth it, even at the Stage 1 level.
gjhsu is offline   Reply With Quote
Old 12-08-2004, 05:37 PM   #11
black05wrx23
Member#: 68642
05 wrx
black
ok go to cobb website and download the map they have for cold air intake use that as ur base map its all the way at the bottom stage 2 93 oct injen thats what its called. oh and that intake is probably making you run lean (from what I have read so becareful when u start moding it more)
black05wrx23 is offline   Reply With Quote
Old 12-08-2004, 05:46 PM   #12
bluscooby
Member#: 27219
Take the intake off you will make more horse power and it will run way better with the factory airbox. Please take it off. The cold air intake map is made for a injen intake not a aem one. Cobb is comming out with there own intake and the only reason they are is becuase people keep asking for them not becuase it will make the car go aqny faster. FOR THE LUV OF GOD put the factory one back on
bluscooby is offline   Reply With Quote
Old 12-08-2004, 05:51 PM   #13
black05wrx23
Member#: 68642
05 wrx
black
bluscooby the difference between the injen cold air and the aem cold air isnt gonna make a difference he can run that map and be ok even though he has an aem cold and not the injen cold air. BUT I AGREE TAKE IT OFF USELESS
AP- question Need help Married AP!! subadrifta06 AccessPort 13 12-19-2007 03:16 PM
cobb ap question speedyshifter Engine Management & Tuning 1 01-08-2005 08:14 PM
STi AP questions -=Fox=- Engine Management & Tuning 0 11-03-2004 01:37 AM
AP question rallyme Engine Management & Tuning 1 10-07-2004 11:31 PM
More AP questions AchmedRodriguez Engine Management & Tuning 9 09-12-2004 09:13 AM
Message Board Statistics All times are GMT -4. The time now is 02:18 PM.
