Old 12-08-2004, 09:29 PM   #1
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Default Optima Red Top Group 35 install pics
Put one in tonight thought I'd make a page for anyone interested:
http://www.scoobymods.com/forums/showthread.php?t=4405
More pics at the link above.
Peaty
Peaty is offline   Reply With Quote
Old 12-09-2004, 10:17 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Thumbs up
Good job and thanks as always Peaty
Hank3 is offline   Reply With Quote
Old 12-09-2004, 04:40 PM   #3
tompetey
Member#: 73034
MY02 OBS
So, I couldn't help but notice that you had some aftermarket cables coming off of your battery terminals....What are you running those to? I am getting a small amp installed in my car and I will be getting a new battery. For some reason, someone suggested a yellow top. I do not understand the differnece between the two. Long story short, if you are running additional accessories off of your red top, I might go that route! Also, if I do not mind the length of the holding rods, is there any reason that I shouldn't just leave them an incha and a half longer? (other than cosmetics)
tompetey is offline   Reply With Quote
Old 12-09-2004, 04:58 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The Yellow Top is more of a deep cycle battery and is recommended for applications where high-current accessories are installed in the vehicle, particularly stereo systems that are likely to be used for long periods with the engine off. This type of use can damage standard lead-acid batteries if they are allowed to run down to a discharged state, but the Yellow Tops can tolerate hundreds of repeated full discharges without any ill effects. The Red Top is referred to as a "starting and ignition" battery and is intended more as a direct replacement for vehicles with only minimal aftermarket accessories installed. A Red can still take a number of discharges safely, but not on a regular basis and not nearly as many as a Yellow.
I've had a 35/75 Red Top in my car for over two years now and it has performed very well. I don't have a big system, just an aftermarket HU, although I do have a 50-watt amateur transceiver.
Old 12-09-2004, 05:08 PM   #5
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Forester
[quote=tompetey]So, I couldn't help but notice that you had some aftermarket cables coming off of your battery terminals....What are you running those to?
The cables are the HyperGround Grounding Kit (I moved it from my RS when I sold it, not sure it does a heck of a lot but I had it so I threw it on) and you can see a fuse holder that's for my auto-IC spray pump.
Mulder answered the question nicely, I don't plan on installing an aftermarket stereo super system so for me the red top is fine.
No reason to change the rods other than looks. I was tempted to just hit the silver nuts with some black paint and call it good. Eventually I'll get around to getting the right rods
Old 12-09-2004, 05:42 PM   #6
tompetey
Member#: 73034
MY02 OBS
Thanks for the info guys - I don't plan on having the amp (which is only 400 watts) running anything more than my components and only while the car is running so maybe I'll just get the red top. I will have to check the price difference! Again, thanks for the good advice guys!
Another thing, will the battery help if I am getting some goofy headlight dim (they are really quick and sporadic)? They happen with the radio off and with the radio on.
Old 12-09-2004, 05:50 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Only if a weak battery is the cause, otherwise no. Actually I'd recommend finding and fixing the cause of that before installing a new expensive battery, lest you ruin it with a screwy electrical system. Start by checking the battery terminal connections for cleanliness and tightness, then check all the grounds, then put a voltmeter on the battery and make sure the alternator is charging properly.
Old 12-09-2004, 05:57 PM   #8
tompetey
Member#: 73034
MY02 OBS
since I am not in possession of a voltmeter, should I just bring it in to like an autozone where they can test for free? I have cleaned the terminals previously and they are tight. This same thing happened in my other Subaru (97 Legacy GT) and I tried everything including new battery, alternator, ground cables - nothing helped - why are my Subarus cursed?
Old 12-11-2004, 09:57 AM   #9
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Yes check all the grounds, bad grounds can cause funky things to happen. There are quite a few under the hood.
http://endwrench.com/images/pdfs/GroundsInfo.pdf
Optima Yellow top Group 35 Deep cycle battery. GARGOYLE SCIC Private Classifieds 8 01-25-2010 06:24 PM
FS: 4 Optima Red Top Group 35 Batteries Brand New triniboy Canada Region Private Classifieds 0 10-19-2009 05:39 PM
Optima Red Top 35-910 Bishop Southern California Impreza Club Forum -- SCIC 22 11-17-2008 10:11 PM
wtb 090-04 legacy subwoofer. optima red top 35 battery lgkahn NESIC Private Classifieds 0 10-02-2007 08:57 AM
Optima Red Top Group 35 R DrBoy01 Normally Aspirated Powertrain 18 05-02-2004 02:29 PM
