Old 12-08-2004, 09:04 PM   #1
05rswagon
Member#: 75371
2011 WRX Prem Hatch
Default 05 wiring aux lights help
how to get wires into passenger compartment from th engine bay. I found an offwhite plug in the firewall is this a hole I can use
05rswagon is offline   Reply With Quote
Old 12-09-2004, 06:29 PM   #2
05rswagon
Member#: 75371
2011 WRX Prem Hatch
bump
Old 12-09-2004, 10:37 PM   #3
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
This is on a my2002 impreza. It may be the same for your case.
satrya is offline   Reply With Quote
Old 12-10-2004, 11:59 AM   #4
brunetmj
Member#: 8023
2004 2.5 RS
On the passenger side of the engine bay there may be what looks like a vacuum hose going into the passenger compartment. Some wires can be passed through the surrounding grommet if their not to thick. I haven't seen an 05 though.
brunetmj is offline   Reply With Quote
Old 12-10-2004, 01:18 PM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
I'm not familiar with the my2005, but if you're curious, you can try and open the plug, and run something stiff without sharp edges through. See if it comes out somewhere on the other side.
Another location that Mulder often points out is a grommet near the brake pedal. From the cabin, look for a blind grommet near the pedal, remove them, and try to run something through. It should come out into the engine compartment. You may have to raise the car to see where it comes out, as it is rather low. My guess is this grommet should still be available for the my2005 imprezas.
Old 12-10-2004, 03:37 PM   #6
shizzlenizzle
Member#: 77052
1977 Pontiac
remove the washer bottle and under the power booster push out the rubber plug, this will put you right behind the pedals
shizzlenizzle is offline   Reply With Quote
05 STi Aux wiring help needed. WhiteKnightSTi Electrical & Lighting 3 10-19-2009 12:41 AM
Wiring gods please help! complicated aux light circuit jdubya301 Electrical & Lighting 28 03-07-2008 10:43 AM
Need aux lighting wiring help jbogli New England Impreza Club Forum -- NESIC 1 07-17-2007 03:05 PM
Need some Wiring Help: OEM Fog Light Switch & Aux. Lights! nxwrxfx Electrical & Lighting 3 03-23-2007 07:35 PM
Wiring Aux. Driving Lights Ryan24 North West Impreza Club Forum -- NWIC 37 01-17-2004 02:50 PM
