Old 12-08-2004, 09:16 PM   #1
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Default 2004 WRX STi VF39 turbo on 2004 WRX?
My WRX is currently at Cobb Stage 2 with TMIC. I have an opportunity to swap out my stock turbo with a stock turbo out of a 2004 STi.
Can this be done without any issues?
I am assuming the stock turbo is a vf39? Correct?
Will i also need STi injectors and larger fuel pump?
Can i just swap fuel pumps as well?
Any help would be appreciated!
Thanks,
~Zach
phenemwrx is offline   Reply With Quote
Old 12-08-2004, 10:07 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You will need:
Sti injectors
Fuel pump
Different engine management
Old 12-08-2004, 10:14 PM   #3
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
I hope you dont mean "trade" turbos with the STi! That would suck for him.
VideoGameWrx is offline   Reply With Quote
Old 12-08-2004, 10:32 PM   #4
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Originally Posted by Unabomber
You will need:
Sti injectors
Fuel pump
Couldn't i just use the VF34 map from cobb? Also modify my stock WRX injectors like many others have done? Finally just swap out fuel pumps from an STi?
~Zach
Old 12-08-2004, 11:07 PM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
the cobb map is made for a vf30/34. the vf39 is *close* to a vf34 but it still has different flow properties. X boost from one won't equal X boost on another.
modified stock WRX injectors flow much more than STi pink injectors. you will be rich with the cobb map.
STis owners swap their fuel pumps to walbro, why would you sway in an STi pump?
MikeWRX-NJ is offline   Reply With Quote
Old 12-08-2004, 11:26 PM   #6
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
You'll want to get of STi "pink" in injectors. Also t w/ those you'll want to get a walbro pump. You can actually max out the stock STi pump before the injectors will max out.
SubieStyle is offline   Reply With Quote
Old 12-08-2004, 11:29 PM   #7
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
ok guys thanks a bunch, looks like i have to wait until cobb releases there accesstuner!
~Zach
Old 12-09-2004, 01:15 AM   #8
InfamousDX
Member#: 25413
For the price of the upgrade to the Tuner compared to the power you'd get, it would probably be more economically efficient to just buy a vf30/34... they would make more power anyway.
Old 12-09-2004, 09:52 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
two threads over there was speculation that there IS a vf-39 accessport 2.5 map
you won't need a fuel pump for the stage 2.5 but its a good idea any way (2.5 is tuned for the stock fuel pump)
Old 12-09-2004, 10:44 AM   #10
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
I am not sure i understand what you are saying here, is there a map made for the 2004 WRX that supports a vf39 upgrade?
~Zach
Old 12-09-2004, 11:45 AM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
He is saying that someone else's post speculated that Cobb has a VF-39 map. According to their website they don't. Call them directly and post what they have to say for others.
Old 01-25-2005, 04:21 PM   #12
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I emailed them and they told me that there is no map and they don't plan on making one available.
Jard is offline   Reply With Quote
Old 01-26-2005, 06:51 AM   #13
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
This is true but you know most of us AP people are going to get the Tuner anyway.
GDR is offline   Reply With Quote
Old 01-26-2005, 10:22 AM   #14
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Several people are running the vf-39 on the vf-34 map without consequence. If anything you "might" be alittle rich. Same compressor side, however, some vf-39's have a smaller hot side(p17 rather then a p18)...so your choice.
Swine is offline   Reply With Quote
Old 01-26-2005, 10:44 AM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i agree with swine. though i don't have any cobb stuff, the turbos are very very similar. the only issues i could see arising are with the stability and control of boost levels.
Old 01-26-2005, 11:05 AM   #16
Rickyh
Member#: 40453
I have a vf39 and with all supporting mods and I tried the utec stage 4 map and it would knock a bit at around 5.5k. My vf39 has the p17 hot side.
Rickyh is offline   Reply With Quote
FS: Custom TMIC for STi-style turbo on 08+ wrx CHEAP kyledooley Engine/Power/Exhaust 4 04-28-2010 10:14 AM
FS: Custom TMIC for STi-style turbo on 08+ wrx CHEAP kyledooley MWSOC Private Classifieds 2 04-28-2010 10:13 AM
Stock STI VF39 turbo on a WRX degeneration-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-13-2006 04:28 PM
Sti VF39/Tmic on '05 WRX cellobro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-14-2006 11:09 PM
03 wrx STi Short Shifter on 05 wrx? SUBYDOODIE Transmission (AT/MT) & Driveline 1 10-24-2004 07:21 AM
