12-09-2004, 03:31 AM | #1 |
Member#: 40788
SCIC
Vehicle:2004 WRX Sedan WRB |
DeltaDash Refresh Rate?
I currently have an Autoenginuity OBDII Scan Tool and I find that the refresh rate on it is rather slow. I'm looking into getting a DeltaDash, but I'm wondering if the refresh rate on the info it displays will be any faster. For instance, both of these can read engine RPM, but does it read & display it fast enough to be used as a shift light?
I'm hoping that the Deltadash is a bit faster in ready and displaying it's data since it's subaru specific while the autoenginuity is more of a general use device. And if it is, anyone interested in buying it off of me? Jason
12-09-2004, 01:00 PM | #2 |
Member#: 59287
TXIC
Vehicle:2007 WRB WRX 2004 WRB WRX (RIP) |
To start, you are looking at apples and oranges here. Your current tool is OBD2 and works on most cars post 96. It follows the OBD2 spec, which is generally 200ms polling interval. On older ECUs this is about as good as it gets. On new ones, this is much slower than it needs.
The Delta Dash is late model Subaru specific. It is not OBD2 compliant, and will not work on other cars. It is also limited to a small number of cars that you own. (No scanning the entire club) However, since it is ECU specific, it can use the Subaru Select protocol, and have a much faster pooling interval. Before you do this, however, see if there is a way to change the pooling interval of your tool. For Elm32x based tools, it is a software setting, and you can pick whatever you want. I just went faster until I started getting errors, and then backed off. |
12-09-2004, 01:30 PM | #3 |
Member#: 39235
DD can sample up to 20ms.
12-09-2004, 04:30 PM | #4 | |
Member#: 5477
Vehicle:2007 R171.473 2009 SWP Spec B |
12-09-2004, 08:43 PM | #5 | |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
12-09-2004, 09:24 PM | #6 |
Member#: 40788
SCIC
Wow, lots of good info. Thanks alot guys. If I can't increase the sample rate on mine, then I'll probably sell it and get the DD.
Jason |
refresh rate on monitor | stuttgart | Off-Topic | 5 | 07-16-2004 10:11 AM |
"How do I change the refresh rate on my Yahoo browser? | Kaiser | Off-Topic | 37 | 06-28-2004 04:25 PM |
Eye strain and Refresh Rate | The_Triton | Off-Topic | 51 | 05-11-2004 07:21 PM |
Changing refresh rates for gaming? | Cyberdemon | Off-Topic | 0 | 12-06-2003 08:07 PM |
UTEC & Refresh Rate | chuglobal | Engine Management & Tuning | 4 | 05-23-2003 03:14 PM |
