Old 07-03-2001, 09:50 AM   #1
bahboy20
Member#: 6726
Default Going from N/A to Turbo
I have a 2002 RS and am thinking about adding a small turbo kit on it. I was wondering if anyone had any insight into the costs and problems associated with it, web sites, magazines to check out, people who have done it already, which turbos to use and not to use, etc.
I am trying to find a small and cheap turbo to start with (would even go the used route if necessary). So far the only mod I have it the ganzflo being delievered this friday (thanks larry!). Aside from the turbo itself, what else would I need-- an IC, etc...
Any help is appreciated.
Thanks,
Bahboy20
bahboy20 is offline   Reply With Quote
Old 07-03-2001, 11:46 AM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
There is a bunch of information available within the Turbo Powertrain forums. One of the problems going around right now is found here.
There are many other issues including overheating (on MY98's), broken trannies, and partial throttle bucking caused by MAP sensor overload.
My writeup for adapting a legacy turbo can be found here as well as blaster88's writeup here
You can also find install instructions for a custom IHI install here, so you can get an idea of what is involved with putting a turbo kit in.
Finally, I would recommend hunting down a book called Maximum Boost written by Corky Bell.
-Jon
Looking to go from Stage 0 to Stage 2.5...Need Expert Advice jsavage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-19-2005 03:00 PM
Going from NA build to Turbo build G.Subramaniam Normally Aspirated with bolt-on Forced Induction Powertrain 33 07-16-2005 10:47 AM
Going from VS 1 to VS 2, how to tune MikeWRX-NJ Engine Management & Tuning 2 09-17-2003 10:33 AM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 03:19 AM
going from N/A to turbo.. Maybe booger Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-17-2002 03:28 PM
