Old 07-03-2001, 10:21 AM   #1
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Default S-AFC, positive intake maniford pressure?
When I open the throttle up the intake pressure on my safc reads zero and stays there untill I let off the throttle. I know that there is some positive pressure but it will not read it. Is it possible the the factory sensor cannot read positive pressure?
adeck is offline   Reply With Quote
Old 07-03-2001, 10:41 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
would it maybe be reading the vacuum pressure? cause that would then be correct...
JGard is offline   Reply With Quote
Old 07-03-2001, 10:49 AM   #3
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Yes that is what it reads but there is no vaccum at wot, at wot there should be + intake pressure with my homemade *ramair*.
Old 07-03-2001, 11:01 AM   #4
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
just the opposite, I would think...
if air is being sucked into the engine, it is defenitely creating a vacuum behind it. check out the hoses that go into the air box... those count on air being sucked out of them. the more the engine pulls, the more it creates a vacuum there.
but, I could be wrong....
Old 07-03-2001, 11:06 AM   #5
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
The more open the throttle is the more equal the pressure would be between the inside and outside of the TB. The less you are on the throttle the harder it is for the motor to suck air in. That's my opinion. What I am trying to find out is if my homemade *ram-air* is actually forcing air in!
Old 07-03-2001, 12:11 PM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I thought that the only way to make that gauge bring to the + side is to get a turbo or Supercharger. I don't see any way to bring that gauge to + w/o it because the engine has to create a vacuum and it cannot create more pressure than the outside world (1 atm = 1012hpa) w/o forced induction (boost).
tmat3 is offline   Reply With Quote
Old 07-03-2001, 12:20 PM   #7
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
yeah, I don't think you're "ramair" is all that forceful...
Old 07-03-2001, 12:33 PM   #8
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Can you explain why the safc is reading zero when the throttle is open? I think the safc would display + numbers but the factory sensor in the intake cannot read positive numbers.
Old 07-03-2001, 12:44 PM   #9
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
What does your SAFC measure vaccum pressure in? PSI? Maybe it is lower than 1Psi and the SAFC doesn't display less than whole numbers.
Just a wild guess.
MY99 2.5GT is offline   Reply With Quote
Old 07-03-2001, 12:47 PM   #10
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
It measure is mmHG, I have acctually got a +0.01 on the safc.
Old 07-03-2001, 01:26 PM   #11
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
? anyone ?
Old 07-03-2001, 01:47 PM   #12
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
My votes go with:
and:
-WaC
Wayne
wac is offline   Reply With Quote
Old 07-03-2001, 01:56 PM   #13
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
dammit, I am gonna prove this. I am not saying this *ram-air* is forcing a lb of boost or something, I am just saying that there is positive pressure in the intake, it may be small, but it is greater than equal pressure.
Old 07-03-2001, 01:58 PM   #14
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
dude, wayne knows what he's talking about. I'd leave it be.
Old 07-03-2001, 02:02 PM   #15
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Listen, I know what I am talking about there is positive air pressure.
Old 07-03-2001, 02:55 PM   #16
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
If you insist, prove it, then come back and let us know what speed you had to get the car up to to start noticing a ram-air effect.
Albert is offline   Reply With Quote
Old 07-03-2001, 03:01 PM   #17
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
exactly....please prove that all this air will be "forced" into the intake, without forced induction, ie. a turbo
Old 07-03-2001, 03:10 PM   #18
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Default ...
I believe the stock MAP sensor will read positive pressure up to 2 psi.
donjuan is offline   Reply With Quote
Old 07-03-2001, 03:27 PM   #19
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I need a gauge that will measure in +. It seems like the stock sensor doesn't measure +, but it has read +0.01 on the SAFC at about 35 MPH 3rd gear.
Old 07-03-2001, 03:29 PM   #20
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I need a gauge that will measure in +. It seems like the stock sensor doesn't measure +, but it has read +0.01 on the SAFC at about 35 MPH 3rd gear. If anybody lives near me I will be happy to show you?
Old 07-03-2001, 03:33 PM   #21
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Don't get me wrong, I'm not bashing you or anything, but I would not consider a +.01 reading with an S-AFC and the stock MAP sensor an accurate reading.
Old 07-03-2001, 03:38 PM   #22
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I agree, so what do you want me to do install a boost gauge?
Old 07-03-2001, 03:59 PM   #23
dRu18
Member#: 4034
2005 Infiniti G35c
Ivory Pearl
i think the "ram air" doesn't create enough pressure at freeway speeds to make a difference
dRu18 is offline   Reply With Quote
Old 07-03-2001, 04:07 PM   #24
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
OK listen, picture a 2.5 in a wind tunnel. What the car is doing is cutting a hole in the air so, the air that is forced up the hood is being caught by the hood scoop. With my intake "all air comming through the scoop is being guided into the throttle body through a rounded sheet metal box."
Old 07-03-2001, 04:17 PM   #25
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
but it's not like that air is compressed at all. also, is it an air-tight seal from the outside of the hood scoop to your intake? i doubt it.
there's plenty of room for air to leak out. And like I said, it's A: not compressed air, and B: not forced. it more or less "finds" it's way to the intake.
FS: Defi intake manifold pressure gauge 60mm green link greddy18 Interior/Dressup/Audio & Security 0 08-12-2008 12:23 AM
(MA) Defi Meter Intake Manifold Pressure Gauge 4thgenx42 Interior/Dressup/Audio & Security 0 05-11-2008 12:37 AM
[Question] Intake manifold pressure & engine load kashun84 Engine Management & Tuning 1 05-05-2008 11:42 PM
Pole Position S0-3 pressure? scoobystas Tire & Wheel 8 10-08-2003 06:53 PM
Blitz SBC-iD Install-Intake Manifold Pressure? bdowell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-09-2001 12:15 PM
