Old 12-09-2004, 05:42 PM   #1
subenerd
Member#: 72630
2004 STi
Default How long do you warm up your car?
I usually wait until the temp needle moves above the bottom line until I drive(2 - 5 min), and then wait until the needle is at the normal halfway point before I touch 4K+ rpms.
What do you do?
subenerd is offline   Reply With Quote
Old 12-09-2004, 05:46 PM   #2
WimpWgn
Member#: 66580
that's a good habit, it depends on the weather too.
WimpWgn is offline   Reply With Quote
Old 12-09-2004, 05:47 PM   #3
STIgeorge
Member#: 22040
12 FJ Cruiser
Rent-a-car White
Get in, start, put in gear, drive slowly until the temp comes up.
-George
STIgeorge is offline   Reply With Quote
Old 12-09-2004, 05:51 PM   #4
ydant
Member#: 43447
2009 STI
The Good Grey
Drive < 3k, no quick accel until meter reaches normal position (about 1/6th the way above the bottom line). Then I flog it. Only time I let it sit after starting is if the idle is high - then I let it calm down a little bit.
ydant is offline   Reply With Quote
Old 12-09-2004, 05:53 PM   #5
Chris Cuevas
Member#: 75547
2016 STi-ICE Silver
SRP P&P'd VF22 + NOS= RIP
All good answers.. Im right there with you...
Chris Cuevas is offline   Reply With Quote
Old 12-09-2004, 05:56 PM   #6
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
10-20 seconds unless she's covered with snow. In modern, fuel injected cars, it's better to just drive off gently right away than to let the car idle. The computer adjusts the a/f levels so the engine runs smoothly and by driving gently you more quickly circulate oil and more evenly heat up the engine and transmission.
Stanley is offline   Reply With Quote
Old 12-09-2004, 06:00 PM   #7
Impreza_RX
Member#: 68015
2006 WRX TR
Steel Gray Metallic
Start up car. Turn on heater and go back inside house. Take a crap. Then come back to my car and leave.
Impreza_RX is offline   Reply With Quote
Old 12-09-2004, 06:07 PM   #8
subenerd
Member#: 72630
2004 STi
Stanley-
Do you thing there is anything wrong with letting it idle for a few minutes before driving?
Old 12-09-2004, 06:42 PM   #9
Rev1
Member#: 51240
08 Lexus IS350
1-2 minutes when it's cold... then drive it off boost for about 5-10 minutes ... then I drive normally...
Rev1 is offline   Reply With Quote
Old 12-09-2004, 06:44 PM   #10
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
It's actually considered bad for the engine if you let it sit and idle for more than 30-60 seconds.
Just start, let the thing run for 5-10 seconds, then drive. Keep under 3,000 RPM or so until fully warm.
Also, just because the temp needle is at the normal operating temp area, it doesn't mean the oil has fully warmed up (as it takes longer to warm up than anti-freeze)... So if you want to be safe, wait another couple of minutes after "fully" warm before you start getting on it.
JGard is offline   Reply With Quote
Old 12-09-2004, 06:45 PM   #11
Karl
Member#: 13110
Originally Posted by subenerd
Stanley-
You are just wasting gasoline letting it idle.
Drive gently when the car is cold, no need for extended warmup. Your car warms up faster when it is moving.
Karl is offline   Reply With Quote
Old 12-09-2004, 07:06 PM   #12
korpse
Member#: 15386
Thats a very good point that a lot of people don't realize. To put it into perspective, when my water temp guage shows that the water is at normal temperature, my oil temp guage hasn't even started to move yet. It is probably about 50 degrees celcius, and isn't at its running temperature (85-90 degrees celcius) for another 4 or 5 minutes.
To answer the original question, I let my car warm up for maybe 30 seconds if its really cold then i just drive off boost until the car is warmed up...
korpse is offline   Reply With Quote
Old 12-09-2004, 07:22 PM   #13
subenerd
Member#: 72630
2004 STi
you learn something new everyday
Old 12-09-2004, 07:31 PM   #14
NeedAWD
Member#: 30831
2004 WRX
Java Black Pearl
wow. lots of useful advice.
NeedAWD is offline   Reply With Quote
Old 12-09-2004, 07:53 PM   #15
brunetmj
Member#: 8023
2004 2.5 RS
It's also bad to drive a car with to much ice on the windshield. In cold weather states let it warm enough to drive away safely.
brunetmj is offline   Reply With Quote
Old 12-09-2004, 08:06 PM   #16
kbarb03
Member#: 62440
2003 WRX
black
I find it interesting that you say it takes longer for the oil to get up to operating temperature than the engine coolant. I am in Georgia Tech motorsports and last week I asked our engine guy how long it actually takes before the oil is warm enough to go ahead and drive the car hard. His answer "basically right away. The oil gets warm enough real fast. So as long as you arent turning it on and immediately flooring it, you should be fine."
So either he was wrong or the oil doesnt have to be up to full temperature before it is safe to go ahead and drive the car.
I generally wait until the coolant guage is up to the 2nd of the 4 lines.
kbarb03 is offline   Reply With Quote
Old 12-09-2004, 08:10 PM   #17
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
I'm not arguing this but can anyone give me a technical answer to why.
Trunk_Monkey is offline   Reply With Quote
Old 12-09-2004, 08:23 PM   #18
Andrman
Member#: 57803
'03 WRX Sport Wagon
World Rally Blue
Is that the Formula SAE team? Those are much smaller engines, which may be why he said that. It could also have to do with the oil system on that particular car. I know our university's car has a very different oil system than most mass-produced vehicles.
Andrman is offline   Reply With Quote
Old 12-09-2004, 08:26 PM   #19
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
start up, keep revs soft and under 3k until temp needle is right smack in the middle
ZoomnWRX is offline   Reply With Quote
Old 12-09-2004, 08:26 PM   #20
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you have an oil temp gauge you can see firsthand that the oil lags well behind the coolant in coming up to temperature. The temp gauge may come up to the normal operating range after a very short time, but it takes a lot longer for the oil temp to come up.
Old 12-09-2004, 08:30 PM   #21
Andrman
Member#: 57803
'03 WRX Sport Wagon
World Rally Blue
There could be many reasons one would say that, I know of a couple:
1) When you let the car idle to warm up it's cold longer than if you started driving. The engine wears more when it's cold because it was designed and manufactured with tolerances for when it's at normal operating temperatures. When it's cold, the cylinders are smaller and therefore wearing more (lots of other parts are at different fits as well).
2) When you sit and idle without moving, the engine warms but the transmission doesn't. So people will think there car is safe to drive hard and really still be driving on a brittle transmission.
Old 12-09-2004, 08:30 PM   #22
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
I wish I could give a technical answer...but letting an engine idle for an extended period of time, cold or warm, is generally worse for it than running at normal operating speeds.
Old 12-09-2004, 10:09 PM   #23
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Unless the rules have changed since the mid 90's, I believe motorcycle engine is often used. The oil temp probably rises faster than those in larger engines.
satrya is offline   Reply With Quote
Old 12-09-2004, 10:14 PM   #24
kbarb03
Member#: 62440
2003 WRX
black
Yeah...the engine we use is a Honda F4i i think. But I was asking about cars specifically.
Old 12-09-2004, 10:23 PM   #25
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
If I'm not mistaken, in a motorcycle (sport bikes) the same oil is used to lube the engine as well as the tranny so its viscosity is slightly diffrent than that of regular automotive oil. Or am I just smoking something and not sharing?
NWWagon is offline   Reply With Quote
How long do you keep your Christmas tree up? StuBeck Off-Topic 25 12-26-2009 10:47 PM
How long do you sit on your Throne? SPCJJ Off-Topic 21 10-25-2007 12:29 PM
Do you warm up your engine? doufdouf General Community 3 09-18-2006 09:55 PM
how long before you adjusted to your car under pressure Newbies & FAQs 22 12-16-2005 03:26 AM
How long do you guys let your car warm? IggDawg Normally Aspirated Powertrain 28 06-02-2002 06:07 PM
