Old 12-10-2004, 01:32 AM   #1
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
Default wrx fuel tank critical in swap? and Cruise control Q too
I will be getting the ball rolling on an upcoming usdm 2.0L swap for my 00RS. I was told the fueltank needed to be swapped as well. Is this true? Will a usdm wrx fuel pump no bolt up to the RS's tank?
Also, I remember something in regards to using a cruise control bracket to accomodate for the shorter throttle cable. Is this necessary? or has there been a fix to this yet? I plan to retain my cruise.
MixeD_MenacE is offline   Reply With Quote
Old 12-10-2004, 07:33 AM   #2
AKGC8
Member#: 1305
2000 Impreza
You do not need the tank. You can swap the wrx pump into the RS's pump housing, or just get a walbro. A 00 RS will have all the emissions equipment needed for a legal swap as well.
AKGC8 is offline   Reply With Quote
Old 12-10-2004, 11:36 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its the <96 tanks than are missing the emmissions stuff
Old 12-13-2004, 12:19 PM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
You just need to relocate the cruise control actuator because the downpipe will go where it is now. If you have a strut tower bar you can bolt it or zip tie it to that. Some people stuff it into the fender.
garface is offline   Reply With Quote
Old 12-13-2004, 06:15 PM   #5
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
A WRX fuel pump will fit in fine. There is no reason to change the tank. As far as the throtle cable goes you will either need to get a WRX throtle cable or relocate the bracket and use the CC spot on it. If you want to make the CC work you are going to have to use the WRX CC unit.
Z
Zephyr is offline   Reply With Quote
Seat swap = no cruise control fateo66 Electrical & Lighting 8 06-10-2010 12:46 PM
speedo and cruise control not working 2002 subaru wrx redrex002 Electrical & Lighting 1 03-15-2009 02:42 PM
Are WRX fuel tanks interchangable with STi tanks? Amazake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2006 02:57 AM
Break-in Period and Cruise Control nightdesigns Legacy Forum 1 04-17-2004 04:24 AM
STi steering wheel swap successful; cruise control intact! Paulie Interior & Exterior Modification 19 04-09-2004 10:41 AM
