Old 12-10-2004, 02:58 AM   #1
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
Question Throwing CEL after install of Utec stage 4
I am running a utec stage 4 and I have the check engine light on. I got a code reader and it says it is due to the catylitic system so I guess that means that because I have the cat in the uppipe and the cat is the downpipe gone that the highflow cat in the mid pipe is not enough to keep from throwing the CEL. How can I fix this CEL I do not want to just disable the CEL light in the car but I would like to get the car to think that the admissions are fine. Any thing I can do?
Thanks
STUDAndring is offline   Reply With Quote
Old 12-10-2004, 03:25 AM   #2
faylix
Member#: 70184
2012 WRX STI
Dosn't the UTEC give you the power to surpress these CELs?
or get a CEL fix. Search it.
-J
faylix is offline   Reply With Quote
Old 12-10-2004, 04:31 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....you have a catted UP with a stage 4????
You REALLY gotta get your ish figured out or you gonna blow it up, quick like.
This particular post is a prime example of doing and NOT knowing....
Old 12-10-2004, 05:22 AM   #4
hernan
Member#: 51477
Please, read before posting.
He has no cats, new stage 4 setup and wondering how to get that cel out.
When you don't know something, asking the right question is an excelent first step.
hernan is offline   Reply With Quote
Old 12-10-2004, 06:19 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
...so I guess that means that because I have the cat in the uppipe and the cat is the downpipe gone that the highflow cat in the mid pipe is not enough...
W T F is the above supposed to mean then????
I did read the post, but english being my first language isn't enough these days, I guess...
Old 12-10-2004, 10:38 AM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
What is the exact code?
It's probably p0420 (rear O2 inefficiency). Either turn off the CELs in the Utec or do the mechanical fix.
Only do the fix once you know the exact code the ECU is throwing. Don't trust universal code readers on the verbage.
mbiker97 is offline   Reply With Quote
Old 12-10-2004, 10:58 AM   #7
Davenow
Member#: 23676
Why dont YOU read before posting, he VERY clearly states that he has a high flow cat in the midpipe, which is 1 cat
ANd he VERY clearly states that he has the cat in the up pipe.
Thats 2 cats, 2 counts of you being an idiot.
You need to learn who NOT to say things like that too. Because in general, if you read something they wrote and think its stupid, its YOU that arent understanding what they wrote. There is a reason that these people are generally known as the ones to go to for these questions.
Now, to the original poster. From what you typed it looks like you have an up pipe cat in there. You are NOT at stage 4 with that cat in there, and your car will never run properly with that setup with that cat in there. Please clarify whether or not you do in fact have a catless up pipe, and if you dont, GET IT DONE.
Old 12-10-2004, 04:47 PM   #8
zaxrex
Member#: 9898
Water Injected Blue
If my engrish reading is correct, and you were writing in engrish...
Step One:
GET THE UPPIPE CAT OUT.
Step Two:
DO NOT DISABLE CEL WITH UTEC. Whe you turn it off, you won't see when your car is screaming, "for the love of God, STOP".
Step Three:
confirm the CEL codes. Make sure that it is for the rear O2 sensor. This can be fixed by, 1) searching, 2)A-soldering in a MIL eliminator or, B-doing the mechanical CEL fix with spark plug anti-foulers.
There is so much good info here that I cry sometimes...
There is also a shload of poopey that sometimes masks all the goodness....
zaxrex is offline   Reply With Quote
Old 12-13-2004, 02:02 AM   #9
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
I do not have a cat in the uppipe only the highflow cat in the mid pipe. And I do not want to disable CEL because then if somthing else goes wrong I will never know.
Old 12-13-2004, 10:10 AM   #10
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
IIRC when you turn the CEL off with the Utec if a new code pops up it flashes the CEL to alert you of a code.
What is the exact code your car threw?
Bouncing of RPMs after instalation of AP stage 2 20SUBIEWRX02 AccessPort 1 04-14-2008 08:50 PM
Cel After Install Utec gaby UTEC 1 03-03-2006 05:31 PM
best place for Turbo XS UTEC Stage 4 install SoCalWRXwagon Southern California Impreza Club Forum -- SCIC 6 06-30-2004 03:19 PM
anyone have a UTEC stage 4 map with ION instead of a VF30 frdawg Engine Management & Tuning 0 04-14-2003 09:55 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-18-2003 11:37 PM
