Old 12-10-2004, 09:21 AM   #1
garie
Member#: 26607
2002 wrx wagon
Default are the stock front and rear endlink bushings for wrx wagon identical??
Hi I was wondering if anyone knows if the bushings for the stock endlinks are the same for the front and rear in a wrx wagon?
thanks!
-gary
garie is offline   Reply With Quote
Old 12-10-2004, 09:26 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
yes they are to my knowledge
Legacy777 is offline   Reply With Quote
Old 12-10-2004, 09:50 AM   #3
garie
Member#: 26607
2002 wrx wagon
from looking at some pics of the wagon front endlinks...is there one bigger bushing and one smaller one?
Old 12-10-2004, 10:36 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
this is correct. one is larger than the other.
what are you working on?
Jamie
www.subiegal.com
Old 12-10-2004, 12:37 PM   #5
Legacy777
Member#: 4800
Isn't it the same on the sedan? All the aftermarket endlinks don't specify between wagon or sedan.
Old 12-10-2004, 09:46 PM   #6
garie
Member#: 26607
2002 wrx wagon
Jamie
www.subiegal.com
im thinking about replacing the stock bushings in the rear and front stock endlinks with polyurethane bushings.
im trying to figure out if the 2 larger bushings in the front use the same bushings as those in the rear(because i found a rear kit only).
do you think if i only replace the bigger bushing in the front, would that improve performance? im just looking at some cost effective upgrades.
Legascgy777-the sedan front endlinks are pillowball endlinks, diff from the wagon front ones.
Old 12-11-2004, 12:59 AM   #7
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Sedan and wagon have different track widths, hence different endlink designs (at least up front).
<--- looking for an upgraded wagon front sway
forced4 is offline   Reply With Quote
FS: Good used Perrin front and rear endlinks 02-05 WRX specialev NWIC Private Classifieds 2 06-01-2009 12:16 AM
FREE!!!!! Front and Rear regular pads for WRX. jungo75 Suspension/Brakes/Handling 10 08-25-2007 10:42 AM
front and rear sway bars for a wagon (05) 05rswagon Impreza Forum 2 01-19-2005 04:33 PM
Front and rear end links for WRX wagon. Have a few ?? WRBLUEWAGON Brakes, Steering & Suspension 7 05-08-2003 10:05 AM
Cusco front and rear sway bars for WRX Z1 Performance Tri-State Area Forum 0 02-27-2002 09:15 PM
