Old 07-03-2001, 01:39 PM   #1
pdlindor
Member#: 7446
2002 Impreza RS
2009 Forester Limited
Question Rear sway bar questions
Hello all.
I've been reading a lot about upgrades, and I'm thinking about the rear sway bar in my MY02RS, but I have a few questions:
What exactly will this upgrade provide?
What does the installation involve?
Will the stock suspension support a 20mm rear sway bar?
Will this throw off the center of gravity towards the rear of the car?
Does this require that I upgrade my front sway bar as well?
Thanks much,
~Paul
pdlindor is offline   Reply With Quote
Old 07-03-2001, 01:59 PM   #2
Mauricio
Member#: 2823
As far as I know, a rear "anti-sway" bar induces over-stear, because it puts more force on the outside rear causing it to break away sooner than with the stock bar. I am clueless about the installation itself, but I do know that you might not need a new front bar depending on how big a rear bar you buy and how you want to set up your car.
I think thats how it goes, anyone else care to comment?
BTW- you might have a better shot if you would have posted this in the suspension forum.
Mods-Can you help this gentleman and move his thread?
Mauricio is offline   Reply With Quote
Old 07-04-2001, 01:56 PM   #3
Seeing StaRS
Member#: 5294
^^Good call fellas. I'm looking to find out about sway bars too and I think rally kid has got the right idea, does anyone else have any other thoughts?
Actually check out this link:
How Stuff Works.Com-Stabilizer Bars
Seeing StaRS is offline   Reply With Quote
Old 07-04-2001, 02:01 PM   #4
iBlueVirus
Member#: 4679
installation is pretty easy. if you go to your local dealer, they might even do it for you, but mostly pretty darn expensive. you could do it yourself. just go to the dealer and ask them for the shop manual. I think it's like $25 or something. it's very clean in explaination... good luck! recommand you to get endlinks and mounts later on also...
iBlueVirus is offline   Reply With Quote
Old 07-04-2001, 02:33 PM   #5
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
You really shouldn't need any manualto change out a rear sway bar. It took me probably less than 10 minutes to do mine. Granted it was on a lift, with a borrowed air ratchet, but hand tools are just fine and it's very self-explanetory once you get in there! Sorry, I can't remember the bolt sizes or anything.
imprezadan is offline   Reply With Quote
Old 07-04-2001, 05:17 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
installation is pretty easy on a sway bar. Takes only a few minutes. Basically take out the stock one, and replace with the new one. That's it.
I heard that the rear sway bar will reduce understeer by inducing more oversteer, and the front sway bar will influence the opposite of that. I don't think it does anything to the car's center of gravity, besides maybe a little added weight of the bar vs the smaller stock a bar.
But i think a rear sway bar is an excellent mod. You'll feel a world of difference. Car will feel a lot less unstable when you're goin on those curves
cRayZee is offline   Reply With Quote
Old 07-04-2001, 06:27 PM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
I believe the stock rear sway bar is 13mm. I hear that the highest you should really go is 18mm with the stock suspension. Otherwise you can get TOO much oversteer and be unsafe. I bought the Whiteline Adj. bar that goes from 18mm-20mm-22mm and set it at 18. It is amazing. I got the adj. one so after I do some suspension work I could just go to a stiffer setting.
I hope this helps.
Tats.
Tats is offline   Reply With Quote
Old 07-04-2001, 08:38 PM   #8
Tuning Factory Inc.
Vendor
Member#: 3600
Great mod! It was one of the first things I did. Swapped out the rear for a Cusco 22mm bar and set it to maximum stiffness. I still have understeer but much less so and only a front LSD wil cure the rest of it. Install is a snap. I had to remove the passenger rear tire to get the old one off. That's about it. Just a few bolts. Have some one help you so they can push the bar while you put on the endlinks.
Tuning Factory Inc. is offline   Reply With Quote
Old 07-05-2001, 03:01 AM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Hes talking about the 20mm bar thats on the WRX which you can buy through subaruparts.com (cause the 02 RS only has a 13mm bar) and there is NO reason why this wont fit the car, cause its the same suspension
Old 07-05-2001, 05:17 AM   #10
duckie
Member#: 7713
02 wrx
wrb
these two links should answer ur questions and more
http://www.i-club.com/modifications.htm
http://www.scoobymods.com/
duckie is offline   Reply With Quote
Old 07-05-2001, 09:11 AM   #11
pdlindor
Member#: 7446
2002 Impreza RS
Thanks for all of your help. An OEM WRX 20mm anti-sway bar will be my next purchase!
~Paul
Old 07-05-2001, 10:24 AM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
to reinforce what rallykid said, the rear antisway bar will increase oversteer in your car. It also reduces body roll which makes the car feel more stable. Likewise, a stiffer front antisway bar will increase understeer and also reduce body roll.
But to get things straight, lets think about WHY sway bars change the over/understeer characteristics:
two wheels side by side going around a corner. The outside wheel is on a larger arc, thus is turning less sharply and is also generally on better pavement (more free of traction-robbing debris). A car with soft antisway bars will allow the car to roll to the outside, thus transferring more weight to that wheel. A sway bar limits the body roll by transferring force from the outside suspension to the inside by compressing the inside as well. Since less weight is transferred to that outside wheel, it has less traction. Remember, the friction a tire makes on the pavement is equal to the force applied (weight) * area (contact patch, which grows with weight) * coeff of friction (more or less constant). With less weight transfer, the force and area are both reduced, meaning there is less traction on that outside wheel. BUT! you now have more traction on the inside wheel. Only problem is, since it's on a tighter arc and likely on a lesser surface (dust on side of road, perhaps), you get less overall traction, thus causing that set of wheels to slide. If the rear slides, you get oversteer. If the front slider, you get understeer.
Cheers!
nhluhr is offline   Reply With Quote
Old 07-05-2001, 11:20 AM   #13
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
Paul,
Just a couple notes since I have been doing some research and am in the process of getting a new rear bar myself. Rear bars from the old imprezas will fit on the new age Impreza, but there is less clearance for the exhaust which could be a factor if you want to change exhausts. I have heard that WRX front bars will NOT work on the RS. This is unconfirmed, but supposedly it has something to do with the engine mounting braces.
I am getting a Whiteline adjustable rear bar (made for the WRX) so that I can adjust it for track conditions when I start racing the car.
Micah
ylexot is offline   Reply With Quote
Old 07-05-2001, 11:28 AM   #14
Krelkor
Member#: 6630
2001 GC8
black
what do the seperate endlinks do
Krelkor is offline   Reply With Quote
Old 07-05-2001, 02:33 PM   #15
pdlindor
Member#: 7446
2002 Impreza RS
so, i'm now re-evaluating this decision. i still think that the stock 13mm bar on my 02RS is too small, however, now i'm being told that some body roll is a good thing for traction.
so i have a new question, how much roll is too much? should i go 16mm or 18mm instead of the WRX 20mm?
ylexot, where can one buy the whiteline adjustable bars?
thanks again for all your responses,
~Paul
Old 07-06-2001, 12:30 AM   #16
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
Krelkor - The end links are stronger replacements for the stock end links. They also have harder bushings. I've heard that the stocks are too weak for 20mm and higher. I'm not sure this is still true for the new age imprezas since the WRX comes with a 20mm bar. I might just have to slide under the car tomorrow and take a look at them. There are also aftermarket mounting brackets with harder bushings.
Paul - Don't know about how much is too much. Personally, I'm used to cars that oversteer and the stock configuration has a fair amount of understeer. Therefore, I want the heavy bar to give more oversteer. The best prices I've found for the Whitelines is at www.rallispec.com. They may even have some left at the sale price.
Micah
Whiteline adjustable rear sway bar questions WRX_02_227 Brakes, Steering & Suspension 1 05-27-2002 01:12 PM
Rear sway bar question... thebusiness999 Brakes, Steering & Suspension 20 09-13-2001 02:39 PM
Rear Sway Bar Question liquidice629 General Forum Archive 2 06-27-2000 08:33 AM
rear sway bar questions. griffin Technical Forum Archive 4 06-08-2000 10:32 AM
