Old 12-10-2004, 05:35 PM   #1
SupeR2000DudE-E
Member#: 77205
Default HI.. Im new. HIGH TECH QUESTION ;)
I need a second opinion from an outside source regarding large 5 inch lights in front of the path of air travel for the radiator..
any one have a thought on how much a difference it would make?
Any help would be appretiated.
SupeR2000DudE-E is offline   Reply With Quote
Old 12-10-2004, 05:43 PM   #2
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I have never noticed any problems. and mine are 9.5" in diameter.
but ask this guy, he should have the answer for ya: http://forums.nasioc.com/forums/show...2&postcount=20
Rapid_Roo is offline   Reply With Quote
Old 12-10-2004, 05:46 PM   #3
SupeR2000DudE-E
Member#: 77205
Holy ****.. are you blind?
Old 12-10-2004, 05:52 PM   #4
SupeR2000DudE-E
Member#: 77205
The lower grill area is my main concern.. mind you i do not have any other aerodynamic enhancements(read body kit) I simply want bangin ass yellow fog lights for snowwy situations.
I have a setup in mind that would allow dissassembly between use..
thanks for your quick reply
Old 12-10-2004, 06:11 PM   #5
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
try looking in here if you want lighting ideas. ( http://forums.nasioc.com/forums/showthread.php?t=673117 )
Like I said, mine are in the lower opening and I have never noticed anything different.
RR
Old 12-10-2004, 08:01 PM   #6
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
As long as the lights aren't really close to the radiator (like closer than 1 inch), you shouldn't have any trouble at all.
khail19 is offline   Reply With Quote
Old 12-11-2004, 02:14 AM   #7
05 Subaru-STi
Member#: 72837
2005 STi
wr blue
neon is cool
05 Subaru-STi is offline   Reply With Quote
Old 12-11-2004, 10:41 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Originally Posted by 05 Subaru-STi
neon is cool
opinions were not requested, assitance was.
keep your OT idiotic comments where they belong... in OT
Old 12-11-2004, 08:05 PM   #9
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Subie Gal lays down the ownag3...
As for the lamps, you practically need to have the lower opening sealed off to reduce airflow. As long as there is room for the air to flow around the lamp you'll have plenty of cooling. Besides, the upper grill will still be unblocked and if you're really worried, you can throw on a radiator shroud such as the one from speedmonkee.com which will help with directing air through the radiator.
Here's mine and i have no problems with engine temps:
Old 12-12-2004, 07:46 AM   #10
SupeR2000DudE-E
Member#: 77205
wow.. Id hate to cut you off ..
Ok so im gonna start making the brackets i want to now..
just a question... are you using the liscence plate holes for your uper hella's???
Old 12-12-2004, 07:57 AM   #11
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
Jeebas son. I hope the draw from all the lights doesn't cook your alternator.
NWWagon is offline   Reply With Quote
Old 12-12-2004, 12:16 PM   #12
Psydotek
Member#: 44168
2003 Yellow WRX
The license plate holes are only to prevent vibration. The screws bear no weight from the bracket or lamps. The upper bracket is actually mounted to the two top bolts holding the radiator brackets and the two bolts from the hood latch.
As for the alternator, it's doing just dandy. All the bulbs are standard 55w. It's only about 330w being used. I know one guy who only has 4 extra lamps, but runs 130w bulbs in each lamp for a total of 520w and he has no problems.
Old 12-12-2004, 01:12 PM   #13
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
yeah 520W, heated seats, rally computer, gps, stereo... 12 hour night road rally. no problems
Old 12-12-2004, 01:14 PM   #14
Psydotek
Member#: 44168
2003 Yellow WRX
^^^^what he said.
Old 12-12-2004, 04:54 PM   #15
SupeR2000DudE-E
Member#: 77205
I went and measured out the hella Amber 500's... working on bracketing them right now.. I bought some of that flexible steel roding to allow my to generate the angles need to allow for the proper settup.
to those who own these 500's.. would i be ok allowing the brackets to be at a 90 degree angle.? for my "quick swap out" setup . when i was checking them out today i could not tell how much GIVE the mounting brackets allowed.. do they swivell in a complete 180* loop?
id rather Mount them like this = -( than like this _(
Old 12-12-2004, 06:32 PM   #16
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
where are you mouting them?
mounting them like this will allow the most adjustment
O(
II
II
I ended up mounting them like
==O(
Old 12-13-2004, 07:25 AM   #17
SupeR2000DudE-E
Member#: 77205
well.. With that being said i reworked the design I was going for. Now i have a mounting Bracket that runs like so.
|_o(
You guys are really great help. I really appretiate all the input even though I am being Cryptic as hell
I'll Post Pics after my cars finished within the next few weeks.
Any one know where i can get male female 3 wire quick connectors that i can use to wire these up to my exisisting fog switch? I am planning un running a dedicated relay and 12 guage wire from power and then running the switch connection off the fog power line.
Quick disconnect to me means. Bad weather on, good weather off. can hardly wait.
Old 12-13-2004, 12:47 PM   #18
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
|_o(
Radio Shack should have something like that, maybe even a local Autoparts store. I think I probably got them at Fry's.
Don't forget to post up your set up in The Ultimate Aux Lighting... thread
RR
Hi, Im new and have some questions 4x4jeep001 General Community 4 09-07-2009 10:10 PM
Hi.. im new here... CrazyWRXHottie Southern California Impreza Club Forum -- SCIC 26 10-30-2001 10:41 PM
hi, im new mario Newbies & FAQs 17 09-04-2001 07:43 PM
Hi, Im new... rex_ruthor Bay Area Impreza Club Forum -- BAIC 7 08-05-2001 08:03 PM
Hi im new here Asaba Newbies & FAQs 8 01-23-2001 03:03 AM
