Old 12-10-2004, 08:57 PM   #1
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Default How much Power is an ej22t good for stock?????
I have almost picked up two seperate wrecked WRX's, both 2001's in hopes to do a drivetrain swap into my 94 impreza awd. BUT i just picked up this 92 turbo (ej22t) legacy and am going to pull the engine and give it an oem rebuild. When its all said and done with supporting mods to back. What kinda power is a stock rebuilt EJ22t good for? I dont want to take it to overboard because i will be running a stock trans with a tight clutch.
lotus2843 is offline   Reply With Quote
Old 12-10-2004, 09:58 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Well it can hold boost, but with wrx heads it has a very low CR and thoes rods are not all that. Same as any stock subaru block around 400whp for a good lenth of time.
For a stock like set up it should do fine, but you will have to up the boost to make good power and you will have a lag problem.
This thread should answer all your questions.
http://forums.nasioc.com/forums/show...highlight=ej22
Old 12-10-2004, 10:35 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
I have seen bent rods on an EJ22t at a little over 300hp. Just ask SBW he bought the broken engine. The closed deck block isnt gonna keep stock rods from breaking, cast pistons from breaking ring lands, or phase I thrust bearing from disintegrating. It may however keep your cylinder walls from ovaling at 500whp+.
Dont waste your time or money doing a stock rebuild to this engine. It will only cost slightly more for Eagle rods and JE pistons. Some people have run very high boost in these engines, mostly due to the very low CR, but they are just not reliable at these hp levels. 300whp in a daily driven car is a awesome car and about the max I would want to run a stock EJ22t.
Scoobie Steve is offline   Reply With Quote
Old 12-10-2004, 11:16 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
I dissagree on the phase I thing... there are more then a few 400+whp subarus running phase 1 blocks with no problems. I sure wouldnt spend money on JE pistons either.
CP pistons and pauter rods IMO best way to go. There are a few others out there, but not JE. www.crawfordperformance.com has experience with and stocks them.
Old 12-11-2004, 01:01 PM   #5
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
So the engine should hold ~270 horse no problem? thats plenty in a 94 impreza awd. I have a local DSM to contend with (91 eclipse gsx) not stock, says hes got 300 horse, i think more like 250-270...
Old 12-11-2004, 08:01 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I run 280whp on mine, its my daily driver, been 11 months, no issues.
Wedge is offline   Reply With Quote
How much power is safe for an ej22t bottom in an ej205? hotshot2109 Built Motor Discussion 20 11-15-2009 05:03 PM
how much power is a ej205 block good for? SLOWSUBY Built Motor Discussion 13 11-12-2009 07:02 PM
how much power is the stock 06 sti fuel system good for blacknbluewrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-30-2008 04:37 PM
RWD vs AWD: How much power is too much for 2 wheels? Prod Off-Topic 48 03-14-2006 03:08 PM
how much power is a ver2 16g good for gc8gc8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-08-2006 07:33 PM
