#1 |
Member#: 69226
Vehicle:02 WRX Aspen White |
Okay I have searched high and low but to no luck. On a 02 wrx which of the 3 wires on the passenger and drivers side is the high beam wire, the low beam, and ground wire on the headlight harness? I can't find any wire diagrams or posts about which color is which and I really need to know. Thanks.
#2 |
Member#: 28197
SCIC
Here you go.
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Note that it's a common positive, switched ground system. The low and high beam wires are switched grounds, not power.
#4 | |
Member#: 69226
So How would HIDs be hooked up to the factory harness if it requires the low beam? |
#5 |
Trust no one
The ballast positive would connect either directly to the factory common positive, or to battery through a relay switched by the headlight circuit. The ballast negative would be connected directly to ground, the switched ground connections should not be used with HIDs.
Are you installing HIDs in the factory housings or in aftermarket lights? If in the factory lights be aware that they aren't designed for HIDs and the resulting beam pattern is poorly controlled, lots of light for you but also lots of glare for other drivers. This is the reason that such retrofits were banned last year by the NHTSA. For further info please read the HID FAQ at the top of this forum. |
#6 |
Member#: 69226
so which color wire on each side should the positive be connected? i really cant figure this out
#7 |
Trust no one
Drivers side- light blue/white
Passenger side- red/light blue |
#8 |
Member#: 69226
well i cant get them to work, i havent heard of anyone else having any problems, screw these things
#9 |
Trust no one
Get some help from someone in your area who knows wiring. The diagram above tells you all you need to know if you can understand it.
| Thread Tools | |
| Display Modes | |
| 02 impreza headlight wiring issue | garinhash | Electrical & Lighting | 4 | 06-02-2010 12:49 PM |
| Factory speaker wire color codes | alfabc | Car Audio, Video & Security | 7 | 03-19-2006 04:20 PM |
| Factory wire colors | jr34596 | Car Audio, Video & Security | 0 | 04-19-2003 11:33 PM |
| Need wiring color for stock WRX rear speaker wires. | GDA | Car Audio, Video & Security | 0 | 06-10-2001 11:29 PM |
| does anyone know the wire color of the factory knock sensor? | TMR Impreza | Technical Forum Archive | 2 | 05-20-2000 04:25 PM |
