Old 12-11-2004, 10:50 AM   #1
Rally RS
Member#: 70015
Default Alarm Problem in 05
I took my radio out to change the colors in it and got that all dont and then i put it back in and my secerity light in the dash is tripping out and when i press the button to lock or unlock it doesnt flash only makes noise i tried putting it in valet mode same just wiht out the sound .... and i also think the alarm stoped working (we tryed by kicking the tires which used to make it give off a warning which that does no more)
Please help
Thanks
Rally RS is offline   Reply With Quote
Old 12-11-2004, 11:43 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It does sound like it's in valet mode. You tried the proper procedure to take it out of valet mode? (Hold down the unlock button for several seconds with the drivers door open). If that doesn't work and all your fuses are ok it may be time to see the dealer.
Old 12-11-2004, 06:07 PM   #3
Rally RS
Member#: 70015
many thanks ... it worked ... what is the defference between doing that and holding the button until it beeps and no sound any more?
Old 12-11-2004, 06:50 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That just turns the chirp on and off, but doesn't actually change the mode of the alarm. Look on the back of your remote, it shows the button presses to select or deselect the chirp (at least mine does).
Old 12-11-2004, 06:54 PM   #5
Rally RS
Member#: 70015
what does valet mode do?
Old 12-11-2004, 07:07 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It turns off the alarm function while the keyless entry remains operative. The idea is you can leave the key with a valet or repair shop without the alarm going off. Actually unless you have the passive arming option enabled there is no need for valet mode since the alarm can't arm itself automatically.
mis fire/ idle problem in 05 sti jdm2ltrcpe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-29-2009 04:39 PM
05 WRX Factory Alarm Problem ewrx05 Car Audio, Video & Security 3 12-16-2005 02:09 AM
05 wrx alarm problem jag009 Car Audio, Video & Security 2 02-17-2005 07:46 PM
anyone installed aftermarket alarm in 05? Sobelizard109 Legacy Forum 1 07-24-2004 01:25 AM
Problem in the 05 STI ? whymysti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 06-08-2004 03:30 PM
