Old 12-11-2004, 08:55 PM   #1
lee1dew
Member#: 49661
2004 WRX Wagon
Default +50% bulb durability
Hi,
Right after buying my WRX, I replaced the stock headlight bulbs with a pair of OSRAM Silverstars. They're pretty good, put out a lot of light, etc. but now, a year later, they both blew out within a month of each other (broken filament). Are these types of bulbs inherently less durable than regular bulbs or did I just run into some bad luck? I always turn the headlights on after I start the car and turn them off before turning it off.
Thanks!
lee1dew is offline   Reply With Quote
Old 12-11-2004, 08:58 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Do you have working DRLs or are they disabled? DRLs will shorten the life of any bulbs.
Old 12-11-2004, 09:04 PM   #3
zionvlad
Member#: 45212
2004 WRX
JBP
have you done a DRL mod after you installed them? 'cuz it kinda shortens the life of the bulbs when you have your headlights on all the time...
zionvlad is offline   Reply With Quote
Old 12-11-2004, 09:04 PM   #4
lee1dew
Member#: 49661
2004 WRX Wagon
My DRLs are disabled. During the winter, when days are short, I'll have them on during my commute (2 hours total per day), and I drive maybe three hours a week at night, so I don't think the bulbs have gotten that much use.
Old 12-11-2004, 09:18 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't know what the rated life is for the Silverstars and how it compares to the OEMs. However most aftermarket bulbs will not last as long as stock ones or equivalents. There is by necessity a life-for-performance tradeoff. At least with the Silverstars you are getting the performance, unlike the blue bulbs that give you less usable light along with shorter life.
You might try contacting the vendor you purchased them from and asking about any warranty, but after a year I wouldn't expect anything.
Old 12-12-2004, 03:36 AM   #6
V6
Member#: 2703
Y2K GC8
Silver forever
agree
if you need durability you should consider those so called "double life" or " long life" or "extended life" bulbs which claims to be up to 2X longer life than regular bulbs.
V6 is offline   Reply With Quote
Old 12-14-2004, 12:50 PM   #7
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Mulder's right. A year of driving with the lights on is something like 200 hours, right? That's actually a fairly good run for an Osram Silverstar.
High-output bulbs like the Osram Silverstar do have shorter lifespans than their standard-output equivalents.
Conversely, long-life bulbs have very low output.
The tradeoff is a fact of life... So which do you prefer? Seeing better but having to change bulbs more often, or seeing worse but not having to change bulbs as often?
vrg3 is offline   Reply With Quote
Old 12-16-2004, 10:33 PM   #8
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Or not seeing at all when your bulbs burn out at night on a road trip?
Osram Silverstar's last longer then some other high output bulbs but still not as long as OEM's.
phantomsr is offline   Reply With Quote
Old 12-17-2004, 09:06 AM   #9
bmorton
Member#: 43528
2004 Outback Sport
Still using the same Philips VisionPlus +50% bulbs I installed in Oct '03. No DRLs.
bmorton is offline   Reply With Quote
Old 12-17-2004, 11:24 AM   #10
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
phantomsr - That's certainly a risk... Bulbs generally burn out at the time that they're turned on, though, so generally it's not likely to happen right in the middle of the road trip. And you always have spare bulbs handy, right?
I actually usually replace my bulbs before they blow out. As they get older their output decreases even if the filament doesn't break.
50% street 50% not street indytruckboy Brakes, Steering & Suspension 4 11-27-2009 07:29 PM
FS: OSRAM Silverstars +50% H1 bulbs rougeben83 Exterior/Styling 1 02-28-2007 02:50 AM
FS: Bulb Bulb and Bulbs! Name Brand H1s, PIAA 9007 ImpreziveWRX Exterior/Styling 3 11-15-2006 09:55 AM
STI HID Bulb, High Beam Bulb, Blinker Bulbs and Harness PIGGY Private 'For Sale' Classifieds 39 07-09-2006 08:39 AM
50% all around vs 50% front 35% back MPEJ20 Member's Car Gallery 8 06-23-2006 01:04 AM
