Old 12-12-2004, 02:58 AM   #1
Grey Ghost
Member#: 43070
Default how to change the foglight bulb
As stated on the title. On a 02 WRX. Used search but cannot find it. Info will be greatly appreciated.
Grey Ghost is offline   Reply With Quote
Old 12-12-2004, 07:02 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You have to remove the foglight from the bumper, three 10mm bolts (there is an adjusting screw in one corner, don't turn that). Once it's out unplug the connector (you don't have to but it makes it easier), open the rear cover and the bulb is there.
Old 12-13-2004, 12:23 PM   #3
Drav
Member#: 52713
2004 WRX (black)
2000 RS (red)
What about for an 04?
Drav is offline   Reply With Quote
Old 12-13-2004, 12:31 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I haven't looked at the fogs on an 04, but I'd assume it's similar as far as having to remove the lights from the bumper to get to the bulbs.
Old 12-13-2004, 07:07 PM   #5
zionvlad
Member#: 45212
2004 WRX
JBP
it's pretty simple... here's how i did mine, i lifted my car, removed the fender well lining (becareful with those black pins, as they are easy to break) by using a flat head screwdriver to pry the middle part then pull the rest of the pins. then crawl under your car u will see your foglamp housing then unplug the wire and then push the holder of the bulb. thats it, easy.... i have to admit that the driverside bulb is kind PITA to replace other than that it's pretty easy. if you have anymore questions just fire away.
hope this helps.
zionvlad is offline   Reply With Quote
Old 12-14-2004, 03:06 AM   #6
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
for the 04's it's way easier if you take the fog light surround off. trust me. it's not that hard to figure out once you get that off.
Bishop is offline   Reply With Quote
Old 04-27-2005, 02:29 PM   #7
Dolamite
Member#: 41233
2008 Impreza 2.5i
RIP: 2002 Impreza 2.5 RS
My foglight on the driver side is out. I've changed the foglight on my Saturn before, how much would labor be if I took it to a dealership?
Dolamite is offline   Reply With Quote
Old 04-27-2005, 02:38 PM   #8
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
a lot more than 15 minutes of your time. remember your 15 minutes is free. theirs is probably not even pro-rated so what 70 an hour
just remove the three bolts. the upper inside one is the adjustment screw dont turn that as mulder said. twist off the back cover remove and replace.
ATX25RS is offline   Reply With Quote
Old 04-27-2005, 02:48 PM   #9
Dolamite
Member#: 41233
2008 Impreza 2.5i
i kind of remember there being different types of bulbs to choose from when i bought one for my saturn. i just don't want to have one brighter than the other. the passenger side foglight is the original. can anyone suggest a bulb and/or wattage?
Old 04-27-2005, 03:58 PM   #10
ATX25RS
Member#: 4597
55w is stock wattage. i say go ahead and replace both. thats what i was talking about 15 minutes. i would say go with some hella yellowstars. although if you just want to replace one, go to autozone and get their 55w sylvania oem replacement, should be the same color and brightness. but for about $5 each you might aswell upgrade to hellas www.rallylights.com
Old 04-27-2005, 05:06 PM   #11
Dolamite
Member#: 41233
2008 Impreza 2.5i
Thanks ATX25RS.
Old 04-27-2005, 06:50 PM   #12
ATX25RS
Member#: 4597
oh yeah after all that i forgot to mention not sure if you got the bulb size, but they are h3's
Old 04-27-2005, 10:25 PM   #13
Johnzim63
Member#: 33330
2002 WRX 5spd sedan
PIAA Ion Gold. They rule.
Johnzim63 is offline   Reply With Quote
How to change brake light bulb chapelhilldoc Electrical & Lighting 0 05-28-2009 06:07 PM
How to Install H3 Foglight bulbs? johnnybryan Interior & Exterior Modification 1 02-18-2007 02:49 PM
How to change the Low Beam bulbs by yourself? faiwu STi Forum Archive 0 06-30-2003 07:26 PM
How to change fog light bulbs mo168 Interior & Exterior Modification 8 08-22-2002 09:25 PM
