Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-12-2004, 09:36 AM   #1
yellowblaze
Member#: 76682
03 Baja
Yellow (of course)
Default Sport activity lights?
Anyone buy these as an add on after they bought their baja? Just picked up an 03 and I'd like to get them, but I am wondering where the wiring runs that they plug into, and if they are easy to install....
yellowblaze is offline   Reply With Quote
Old 12-12-2004, 11:27 AM   #2
mjalex007
Member#: 66022
2005 Baja Turbo
Go to subaruparts.com and look at the installation guide.
mjalex007 is offline   Reply With Quote
Old 12-12-2004, 05:38 PM   #3
yellowblaze
Member#: 76682
03 Baja
Yellow (of course)
Thanks!
Old 12-12-2004, 07:08 PM   #4
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
The main harness runs along the inside of the pass. side roof rail and plugs in behind the 3rd brake light.The 04 comes with the switch holder already installed,the 03 as to be installed.The relay is different from 03 & 04,i found this out since i bought a kit for an 03 and installed it on an 04.The 03 kit is different from the others.You can install the harness without taking all that plastic off,pull the 3rd brake light and the roof panel screws then feed the harness thru there and slide it to the corner.Its not that hard.Good Luck
ajabobrut is offline   Reply With Quote
Old 12-13-2004, 05:49 AM   #5
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Or you could get a set of Hella 500s for about $75, follow their instructions, run the wires and relay and switch anyway you want.
I have done neither , but if I were to put up some lights it would be the Hellas.
Chris N is offline   Reply With Quote
Old 12-13-2004, 03:17 PM   #6
blubaja03
Member#: 55144
2001 Panda Fozz
1999 OB wagon
Hey,
Yea. $75 for hellas vs. about $400 from subaru. I'm working on mounting mine on the front bumper. Pics to come when I do it.
Frank X.
blubaja03 is offline   Reply With Quote
Old 12-13-2004, 10:44 PM   #7
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Frank go to rallitek. they have a light mount for the baja..
patrick
holland_patrick is offline   Reply With Quote
Old 03-19-2005, 04:52 PM   #8
baja03
Member#: 83018
2003 Baja
dark blue
I would have to go with $50 Piolets from Autozone or Orielly are go with a PIAA light
Old 04-17-2005, 02:22 AM   #9
willitm
Member#: 81992
2003 Baja
agreed!
willitm is offline   Reply With Quote
Old 04-19-2005, 11:44 AM   #10
jason.bogdan
Member#: 82812
2005 Baja Turbo
Monterey Gray
Well, here are pics of mine with the factory sport lights:
2005 Baja Turbo - Front
2005 Baja Turbo - Front Angle
jason.bogdan is offline   Reply With Quote
Old 04-23-2005, 07:59 AM   #11
yellowblaze
Member#: 76682
03 Baja
Yellow (of course)
Havent seen you around I dont believe...where in WNY are ya? If you see an yellow 03 sport w/the lights & a Yellow Mustang Registry sticker on the back window, give a shout, that's me (or my other half who always hasthe truck at work) There's a couple other Bajas I've seen around, a blue turbo, 2 other yellows & a red...
Old 04-24-2005, 01:46 PM   #12
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
anyone know where to get some cheap piaa 's or kc 's ?
cliffhanger is offline   Reply With Quote
Old 04-25-2005, 08:44 AM   #13
jason.bogdan
Member#: 82812
2005 Baja Turbo
Monterey Gray
I live in North Buffalo, daily commute for work is to West Seneca. Myself, I have so far seen a red\grey Baja also in North Buffalo, and an all silver one in Depew; both non turbos. All I have seen so far.
Old 10-27-2005, 06:06 PM   #14
hookupny
Member#: 99354
2003 Baja
Black / Silver
Originally Posted by blubaja03
Hey,
Frank X.
I mounted 2 Baja off road lights directly to the front license plate frame, using the existing holes.. pics on my homepage. No need to drill into bumper.
hookupny is offline   Reply With Quote
Old 10-27-2005, 06:09 PM   #15
hookupny
Member#: 99354
2003 Baja
Black / Silver
Default 'Baja' foglights
I found these ' Baja ' foglights at an Auto Parts store ( Parts Plus ) with hard covers lettered " Baja " for $35.00 and mounted them to my front license plate frame.. check pics of them at my homepage.
Old 10-28-2005, 12:39 AM   #16
canuck37
Member#: 87491
03 Sport
Blk/Slvr
Patrick - Do you have any experience with the Rallitek lightbar and its installation? I tried to get some info on it direct from them but they were not responsive to my question and I didn't want to waste $150 and not have it work right. I can't tell from the web how it mounts, etc.. So far, it is the only bar I have found that atually looks reasonable for mounting lights (don't like the one that has the wings off the licence plate bracket.
http://www.rallitek.com/products.asp...CC=Y&SP=o.com/
canuck37 is offline   Reply With Quote
Old 10-29-2005, 05:24 PM   #17
stu's subie
Member#: 98378
2006 baja
atlantic blue
well i got my factory sport lights to go on all the time they work good when i am on a back country road all i did was to move the e brake light switch forward the only thing that is bad the brake light is on alll the time but i still like to have the light on when i need them now i got my money worth
stu's subie is offline   Reply With Quote
Old 10-31-2005, 11:47 PM   #18
primeministerp
Member#: 77950
2003 Baja
Black/Sliver
anyone have pictures of the rallitek light bar installed?
primeministerp is offline   Reply With Quote
Old 11-03-2005, 07:30 PM   #19
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Default Lights work without E-brake
If you have the sport lights and want too use them like they should have been in the begining heres what you need too do.Pull the trim peices too get too the switch,if you have an 04 Turbo you'll be looking for a solid yellow wire.This wire sends a ground too the switch when the E-brake is pulled.Remove the wire and tape it up,then add a wire too the same place then ground the other end.If theres no yellow wire remove the switch and get a test light and connect it too 12v power pull up your E-brake and check each wire with the probe in the connector for a ground.When you find one grounded release the E-brake too see if you lose the ground,when you find the right one then remove it and add a ground to that spot.If you can't find a terminal too put in place,you could leave it in the connector and cut the wire tape up the other end and add a wire and go too ground.I don't like cutting wires so i got one from work.I found this out after pulling my console too check the E-brake switch out,there's only one wire going too the switch.I can't believe its that simple,should have done this along time ago.
Old 01-15-2007, 02:38 PM   #20
baja03
Member#: 83018
2003 Baja
dark blue
I wish I would of found out about this before I installed my own way.
What it looks like on the out side.
The Activity light switch
Old 01-17-2007, 05:24 PM   #21
bajawes
Member#: 128015
03 baja
yellow
i have been thinking of buying a good set of lights and mounting on the front of the hood, but i'm skeared! if i had the skill and materials i'd put down some fiberglass around it to make like the ones on the rally teams car. but i've never done it or have a clue what it would run. whatcha think?
bajawes is offline   Reply With Quote
Old 01-18-2007, 07:17 AM   #22
baja03
Member#: 83018
2003 Baja
dark blue
sounds like alot of work
Old 01-19-2007, 01:35 PM   #23
bajawes
Member#: 128015
03 baja
yellow
it does sound like alot of work, but, it would look good. still considering just a simple bolt on without the fiberglassing. just not sure how it would look. i mean the wiring can easily be done, just don't know how it would look.
Install Baja Sport Activity Lights gifters Baja Forum 3 06-17-2016 07:56 PM
Baja sport activity lights bypass toolbox1234 Baja Forum 2 06-24-2009 12:11 AM
Baja sport activity lights (roof mounted) toolbox1234 Newbies & FAQs 2 06-03-2009 07:18 AM
Roofrack Crossbar for the Sport Activity light kit. Marc M Baja Forum 3 03-25-2009 09:18 AM
problem with Sport Activity Light installation dfritz Baja Forum 14 02-19-2008 08:02 PM
