Closed Thread
Old 08-10-2005, 08:52 PM   #26
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Bump, added more info
Butt Dyno is offline
Old 09-03-2005, 09:55 PM   #27
Mike Johnson
Member#: 71281
September Bump
Mike Johnson is offline
Old 09-04-2005, 01:49 AM   #28
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Originally Posted by ButtDyno
Brake Info
"How ELSE can I decrease stopping distance?"
The only way to significantly decrease your stopping distance is to put stickier tires on the car or drastically increase downforce. Period. Anyone that tells you otherwise is is lying to you or doesn't know what they are talking about.
Gary
Sheehan Motor Racing
www.teamSMR.com
O.K. I'll take a shot. How about weight reduction? I seem to recall another notable mentioning that weight reduction, especially in the front, can significantly help braking.
If so, some BBKs are much lighter than stock. If you could drop 40lbs from your brakes (I know, that's a lot but there are such claims of 10lbs/corner out there), you may dramatically impact your braking ability and attribute it to your new BBK and rightly so but for the wrong reason.
Just a thought. Anyone have any experience with this?
HerculesPeanut is offline
Old 09-05-2005, 04:36 AM   #29
ChrisF
Member#: 12295
bump for a fantastic thread
ChrisF is offline
Old 09-05-2005, 04:12 PM   #30
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Bump so Biggly Arnie and Uncle Scotty don't have to post so much?
But my doctor says frequent posting in the suspension/brakes forum in NASIOC is good for my carpal tunnel syndrome.
Arnie is offline
Old 09-05-2005, 04:39 PM   #31
Mark Avery
Member#: 10313
2002 WRX wagon
Dropping a significant amount of weight would make a difference, but 40 lbs isn't that significant compared to the overall weight of car, gas, and driver. Loosing 40 lbs of unsprung weight would be great for suspension control, but wouldn't make much difference in braking. Now 240 lbs would be a difference you'd feel.
Mark Avery is offline
Old 09-05-2005, 04:57 PM   #32
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
yeah, you tell 'em mark! you should know, especially with that 200#'s of equipment you schlep everyday.
Arnie is offline
Old 09-05-2005, 05:31 PM   #33
Mark Avery
Member#: 10313
2002 WRX wagon
When I was choosing a career, no one told me being a photographer also meant being a pack mule.
Old 09-05-2005, 05:33 PM   #34
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Arnie is offline
Old 09-05-2005, 06:34 PM   #35
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Obviously, more weight loss is better but how much to be noticable is probably pretty subjective. On a vaguely related note, I just dropped 20lbs off my stock wheel/tire combo and feel a very noticable difference so I thought the same might be said of a BBK.
The more I think (and read) about it, the more it seems that the lion's share of the weight loss (going from stock) is on the rotors. Is that correct?
Old 09-12-2005, 03:34 PM   #36
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
bump for all the brake questions today.
AndyRoo is offline
Old 09-15-2005, 06:38 PM   #37
Butt Dyno
Member#: 17301
is the "dark side"
Bump5
Old 09-15-2005, 07:01 PM   #38
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
So continuing the train of thought. If the weight savings comes from the rotors and a BBK doesn't buy much (if anything) for the street, a good upgrade to stock brakes might be a two-piece rotor and some pads. The cost concious (like me) might even wait and do it at some point in time when brake work becomes necessary.
1. What "good", light weight two-piece rotors are out there to replace my stock rotors?
2. Assume that having quiet brakes is the most important feature in a brake pad followed by NOT wearing out my new rotors (see #1 above). Given that, is there a pad out there that performs better than stock in braking without giving up on the noise/rotor wear requirements?
Yes, yes, I've searched but no one has given requirements quite like these. In fact, I suspect that I will probably have to go with the factory pads, given my requirements, but it is worth asking.
Old 09-21-2005, 09:25 PM   #39
Butt Dyno
Member#: 17301
is the "dark side"
Bump - I reorganized some of the stuff.
I took a first crack at organizing the coilover options into categories, but that's a bit iffy at this point. Any suggestions appreciated.
Old 09-21-2005, 09:26 PM   #40
z3coupe
Member#: 13540
2006 MKV GTI
Definately worth yet another bump! Should include links to this from the motorsports forum!
z3coupe is offline
Old 10-02-2005, 08:22 PM   #41
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
buttdyno...with your new super mod skillz can you sticky this?
and bump.
- andrew
AndyRoo is offline
Old 10-02-2005, 08:34 PM   #42
Butt Dyno
Member#: 17301
is the "dark side"
My super mod skillz only extend to teh Mid-A. I figure someone woulda stickied it by now if they liked it
john
Old 10-03-2005, 12:12 PM   #43
ericb49
Member#: 11147
Subscribe
ericb49 is offline
Old 10-16-2005, 12:58 PM   #44
Butt Dyno
Member#: 17301
is the "dark side"
*bump*
Old 10-16-2005, 01:47 PM   #45
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
With so many bumps, I thought I would reiterate my last question. I've yet to find an answer to either.
Thanks,
Old 10-31-2005, 04:27 AM   #46
garie
Member#: 26607
2002 wrx wagon
bump for good read
garie is offline
Old 10-31-2005, 10:19 AM   #47
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Excellent stuff!
One addition: you might want to point out that even though coilovers may have several inches of thread on the strut body, there is only one correct ride height given the position of the piston in the damper. Coilovers are all designed for a specific ride height, and will not function optimally if adjusted far outside of that height (just like lowering springs on struts). So the typical noob thought process, "I'll get coilovers so I can slam it on Tuesday and jack it up for winter" is completely wrong.
The exception to the above is the very few and very expensive high-end coilovers that allow height adjustment at the spindle end. But since that's about 1% of what's sold, it's a small exception.
Jon Bogert is offline
Old 10-31-2005, 12:27 PM   #48
Butt Dyno
Member#: 17301
is the "dark side"
JB: Added
Old 11-01-2005, 02:11 AM   #49
EarlQHan
Member#: 90215
Bump for a good write-up
EarlQHan is offline
Old 11-05-2005, 08:59 PM   #50
thomez
Member#: 90921
2004 STi
PSM/charcoal BBS
awesome read
bump for noobs like me
thomez is offline
Closed Thread
what is the best brake pads for me ? Mr. SUAVE Brakes, Steering & Suspension 9 09-12-2006 01:55 PM
AST Sportline 1 Coilovers, EBC brake pads, STi springs, WRX front brake setup fourdegrees Suspension/Brakes/Handling 23 08-24-2006 07:07 PM
What is the purpose of steel brake lines? impreza2002 Brakes, Steering & Suspension 26 12-19-2002 11:43 AM
brake pad installation: what is the goop you smear on the pads? edkwon Brakes, Steering & Suspension 6 07-08-2002 01:25 PM
