Old 12-14-2004, 09:19 AM   #1
1993 Legacy
Member#: 75875
Default tail lights and front position lights not working
Hi,
I have no position lights on my car (1993/1994 Legacy automatic 4WD station wagon with air suspension). Nothing seems to light up when I turn the lights switch on one step. The second step lights the headlights up. The flasher works as well as high beam. However there are no back lights on ever. The flashers, brake lights and back up light work. I have checked the fuses in the inside fuse box on the left hand side (drivers side) underneath the dash and there seems to be no power in the slots marked back light. Can some one give me some pointers as to where to start looking. I have just noticed that the car has fuses all over the place.
Thanks and best regards
Dusan
P.S. I have not noticed this before as the car was neither registered nor driven.
1993 Legacy is offline   Reply With Quote
Old 12-15-2004, 05:01 AM   #2
1993 Legacy
Member#: 75875
Hi to all,
I just solved the mystery. The switch on the steering column in my car works actually the opposite way than what I read on your site. I have the position and back lights on only when the steering column switch is on and the lights switch as well. Otherwise the position or tail lights do not work. When the ignition switch is off there is no way to run the position or tail lights on. I guess the car was just wired in such a way.
Best regards
Dusan
Help Needed: Key Ring light and Power Door Lock Not Working Linkseal Electrical & Lighting 2 03-24-2010 05:50 PM
Front bumper clips not working? wtfh4xx Interior & Exterior Modification 5 03-01-2010 02:55 PM
WTF: MY brake lights and front signal lights won't turn off 05ImprezaRS General Community 7 04-10-2007 06:59 AM
front and side left blinker not working Der_Dude Electrical & Lighting 1 09-11-2005 09:16 PM
Tail lights and front running lights won't turn off. pcpolo Electrical & Lighting 7 06-21-2005 03:13 PM
