Old 12-14-2004, 04:45 PM   #1
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Default How to Change your cluster lights
I decided to do some experiments with leds... and here's the conclusion
do: blue and white
dont do: red and amber
the only color I didnt try is the UV color... but I dont think anyone wants it anyway
here how I did it:
I tried the leds from 2 different website: #74 for the cluster
autolumination.com perfect size, plastic butts easy to swap
superbrightleds.com wont fit to the cluster
Turn the lights switch off before doing this
1. remove the cluster frame by removing 2 bolts attached upside down, and pull the frame out (there's two small clips holding it)
2. remove the 3 bolts that's holding the cluster, and take the cluster out so that you can reach the back. The 02-03 models need 5 bulbs.
attn: some bulbs are polarized... when you install a blub and it lit right away, take the bulb out of the socket and put it the other way around
here's what I tried
I didnt have a photo of my orange cluster, but it sucks anyway
blue bulbs... nope, not blue enough
red leds
blue leds
white leds
If there's more interest or confusion in doing this I'll try to make a photoed instruction
feiron is offline   Reply With Quote
Old 12-14-2004, 04:57 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
cool...this is helpful...did you remove the green film? do the whites not look that white or is it just the pic? i was thinking about doing mine in white...but hadnt really seen it done beofre...
ATX25RS is offline   Reply With Quote
Old 12-14-2004, 05:09 PM   #3
ATX25RS
Member#: 4597
also ...the superbrightleds that you tried were just the bulb or the base also? i see the different in sizes of the bulbs.....but i dont know if the bases would also be different...
Old 12-14-2004, 05:31 PM   #4
Moods
Member#: 71961
2003 WRX Sedan
MBP
I really like the Blue LEDs that you used...
I know you said #74 on autolumination.com but the only #74 i found was to get bulbs...
I've read almost every single HVAC and cluster change of bulbs but i still have yet to be able to find the exact bulbs that people are talking about. I think i know the process of installing them, but I just need to find those leds! I don't mind if you tell me that it's completely obvious and that they were right under my nose the whole time... i'll be the first to say "ahhh... duh, i'm retarded", but until then i still want to find them.. lol
Moods is offline   Reply With Quote
Old 12-14-2004, 05:44 PM   #5
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I didnt do anything else other than changing the blubs with leds
and the white is bright... not visible at daytime tho... unlike those electric clusters on the legacy and stis but still look awesome at night
Old 12-14-2004, 05:45 PM   #6
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I tried comparing the two #74 leds from both vendors... the ones from superbrightleds is a little bigger...
Old 12-14-2004, 05:46 PM   #7
feiron
Member#: 62327
2005 WRB STI
[S600BY]
http://autolumination.com/74.htm go there and just scroll down my friend
Old 12-14-2004, 06:36 PM   #8
Moods
Member#: 71961
2003 WRX Sedan
MBP
Thanks, i did actually see that... it just said "bulbs"... so i was unsure if those were the first "blue bulbs" you posted or the second (better looking) picture of "blue leds"
Were those #74 the same that you used for the hvac? i found this on another post:
According to the other posts I've seen it looks like if you're doing bulbs you'll need:
8 (+/- 2) size 74 bulbs for the Instrument Panel
1 (+/-1) size 74 bulbs for the Keyring
2 (+/-2) size 194 bulbs for the HVAC
Does that seem like the right amount/kind of bulbs? I think you said you only needed 5 for the instrument panel. I'm just planning on ordering some bulbs, but i'd like to try to get them all at once, no sense in spending a ton in shipping for leds
Old 12-14-2004, 07:09 PM   #9
Handsdown
Member#: 29355
how does that change the color of the needles?
also, why not red? it looks a little dim but not too dim and i like the look of it better...
Handsdown is offline   Reply With Quote
Old 12-14-2004, 07:38 PM   #10
feiron
Member#: 62327
2005 WRB STI
[S600BY]
red is ok IMO, but its just not right enough...
the needles will only change color to red.... when you put red leds... with other leds they'll stay yellow
Old 12-14-2004, 07:40 PM   #11
feiron
Member#: 62327
2005 WRB STI
[S600BY]
depending on which year your car is... 02 and 03 clusters are the same so they should need the same amount
those 5 are for the speedo, rpm, fuel, and temp... the other lights suchs as turn signal and the tripmeter are extras... its always a good idea to buy spare
Old 12-15-2004, 12:02 AM   #12
Handsdown
Member#: 29355
i think i'll do red once the holiday season dies down... i've never liked really bright guages, i keep them one or two steps down most of the time.
i might go try to get red 194s for the HVAC right now.
Old 12-15-2004, 12:35 AM   #13
brunetmj
Member#: 8023
2004 2.5 RS
I tired the same bulbs on the 04 gauges, 74's from autolumination.com. Neither the red or blue where anywhere near bright enough. in addition the stock bulbs are two different sizes in the cluster.
brunetmj is offline   Reply With Quote
Old 12-15-2004, 01:57 AM   #14
Handsdown
Member#: 29355
okay, for 2002-2003...
the HVAC are NOT 194. 194 are way too big and they are what you use for your sidemarkers and parking light front thingys. they are 24.
i too just tried this and i took off the green condoms...
the HVAC are not 'filmed' on the back so they shine a dull yellow/orange light that is emitted from the bulb without it's green condom.
the guage cluster, however, does have a green film on it and even without the green condoms STILL SHINES GREEN.
just look at how much brighter the HVAC is than the guages in the above pictures for proof.
i do not think this is going to result in a BRIGHT guage cluster until you open up the guages, pop off the needles and scrape off the green film backing.
Old 12-15-2004, 01:59 AM   #15
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I use 2 butt-trimmed #194 for my hvac.. and I swap the leds by removing the hvac face.. I'll take a photo of it when I get home
Old 12-15-2004, 11:30 AM   #16
bahboy20
Member#: 6726
Default yeah
yeah, feiron knows what he is talking about.
i follwed his directions for the hvac and it worked just like he said.
next i am moving onto the speedometer, and expect it to work, just like he said.
i have a 2002, and i will post pics later..
dan
bahboy20 is offline   Reply With Quote
Old 12-15-2004, 02:59 PM   #17
ATX25RS
Member#: 4597
okay so how many of each are there? i was waiting to do this to my RS when i got a definate response......so do they not fit at all? or are there #24 LEDS?
Old 12-15-2004, 03:37 PM   #18
feiron
Member#: 62327
2005 WRB STI
[S600BY]
#24 is for the hvac.... #74 is for the cluster... surprisingly I found that not all #74 will fit the cluster...
I bought #74 from 2 websites and only the one from autolumination.com fit...
Old 12-15-2004, 04:14 PM   #19
Handsdown
Member#: 29355
Please, Everyone- Read the FAQ on how to change your hvac and radio controls that is Sticky'd at the top of this forum... especially the posts on page three...
and it helps if you go ahead and take everything apart(all you need is a phillips head and some prying hands) and look at just what you're getting yourself into.
The one thing I'm not sure of... Does the odometer reset if you disconnect the gauge cluster???
i didn't want to find out last night as i poked around, so i just left it plugged in and tilted it so i could get to the bulbs.
Old 12-15-2004, 06:48 PM   #20
Handsdown
Member#: 29355
of course the problem with leaving it plugged in is that you have to work around the steering wheel, which becomes a problem when you want to find out exactly which blub lights exact portion of the gauge cluster
Old 12-15-2004, 09:27 PM   #21
ATX25RS
Member#: 4597
i was refering to the comment that the MY04 cluster has two types of bulbs...i was clarify whether or not it was in the gauge cluster or in all the gauges and hvacs together...
Old 12-15-2004, 11:19 PM   #22
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
The trip odometer will reset, but the main one will not change.
khail19 is offline   Reply With Quote
Old 12-15-2004, 11:40 PM   #23
Handsdown
Member#: 29355
awesome thank you.
Old 12-16-2004, 01:50 AM   #24
feiron
Member#: 62327
2005 WRB STI
[S600BY]
dan
glad you did yours well
the next generation of the subies better have either red or blue interior lights... green makes me sick
Old 01-01-2005, 05:57 PM   #25
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
No, just the trips reset.
Trunk_Monkey is offline   Reply With Quote
Tutorial: How to change your clock to blue, red or whatever color you want lennyTR Electrical & Lighting 45 09-03-2014 04:11 PM
How to change climate control lights? in a 2002 wrx Speedster329 Newbies & FAQs 1 07-29-2009 03:46 PM
how to change 05 fog light BKRush Newbies & FAQs 9 02-08-2009 11:44 AM
How to change WRX interior light from green to red? eric94501 Electrical & Lighting 3 02-05-2005 06:10 PM
changed dash color/how to change cruise control light? wrx_n_ah Electrical & Lighting 16 04-24-2003 03:01 AM
