Old 12-14-2004, 07:43 PM   #1
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Default 6mt and gear noise on decel
If I engage the clutch and throw it into 1st or second gear while coasting or stopping, and leave the clutch in, I can hear gear wine. Like reverse in my 5mt. Same thing. Gear wine. It may be there under power, but my car is kinda loud. The turbo whistle and exhaust cover most things up.
Does the US 6mt do this as well? Any 6mt for that matter. This tells me the gears are closer to straight cut or not a helical as most. This would definitly would count towards overall strength. I am guesing they all do but would like to confirm.
Either all 6mt's do this, just JDM 6mt's do this, or just mine does this because I have Zero Sports gears in there.
ebeck is offline   Reply With Quote
Old 12-15-2004, 09:16 PM   #2
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Nobody listens to thier 6mt?
Old 12-15-2004, 11:45 PM   #3
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
My STi's 6speed sounds like a rally car on a tarmac surface. Its whines and I love it . Makes me feel like Petter Solhberg. Brrr brrrr (insert subaru boxer sound) . I think this noise is normal, but just to be sure check your transmission oil level. And when in doubt call Zerosports.
Old 12-16-2004, 01:18 AM   #4
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Ooil level OK. Ok, so 6mt has gears that are closer gears to straight cut than helical for 1 and 2 at least. Thanks.
Old 12-16-2004, 01:34 AM   #5
ElJefe
Member#: 32968
2002 WRX 6 Speed MT
'05 Evo GSR, 03 ///M3 SMG
I dont hear anything on mine, its an 05 jdm sti 6 speed.
ElJefe is offline   Reply With Quote
Old 12-16-2004, 01:36 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You're kidding, right?
There is a huge amount of transmission whine/noise from the 6MT. It is "normal". That was the first thing I noticed when I bought the car, and it hasn't really changed.
ANZAC_1915 is offline   Reply With Quote
Old 12-16-2004, 02:41 AM   #7
ElJefe
Member#: 32968
2002 WRX 6 Speed MT
I dont hear anything on mine, could be that the suspension has made the car a little loud. But I never noticed any difference between the 5 speed and the 6 speed as far as noise.
Old 12-16-2004, 03:10 AM   #8
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
ebeck; got Group N mounts? My tranny whine was much more noticable after switching to N's. Also, I ran for a month after my swap with no shift boot. A ton of noise comes through there. A little bit of material on the backside of the boot can make a large difference.
fragment is offline   Reply With Quote
Old 12-16-2004, 11:10 PM   #9
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i dont hear anything. Im using stock 2.5RS motor mounts and stock 6speed tranny mount.
ImprezaRSfan! is offline   Reply With Quote
Old 12-17-2004, 12:11 AM   #10
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
Ditto... Been hearing it since day 1.
-Mike-
CreoWRX is offline   Reply With Quote
Old 12-18-2004, 09:40 PM   #11
beefstuinit
Member#: 70079
2011 WRX Limited
Metallic Grey
Gear whine is normal on the 6mt and the 5mt. 6mt is built to be strong yet not prohibitively expensive. Thus it's very strong, without lots of harmonic dampning etc that prevents/silences natural gear whine.
beefstuinit is offline   Reply With Quote
Old 12-20-2004, 09:07 PM   #12
Diode663
Member#: 70325
03 Wrx Sedan
WTB Rear Lateral Links
after a friend rearended me at about 10 mph i experience constant metal on metal and grinding and whining... not so much when under load.. but when i let off the throttle its really bad. i personaly dont think the rearending had anything to do with it but you never know... it also could have been my tire sizes were off and finaly killed the center diff.... any input?
Diode663 is offline   Reply With Quote
Old 12-21-2004, 01:16 AM   #13
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Oh yea! Group N mounts on Tranny. Completly solid. No holes. You guessed it. STi on motor.
Old 12-21-2004, 01:17 AM   #14
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Tires need to be < 1/4 difference and even then only short distances. Preferably all the exact same.
Noise on decel out of my 02 12sechatch Transmission (AT/MT) & Driveline 2 05-04-2010 03:49 PM
08 STI TONS of gear noise on decel gathermewool Newbies & FAQs 10 02-19-2009 01:00 AM
TROLL's Wingless, Scoopless, 6MT and Brembo'd Bugeye on 17x8.5 +40s TROLL Member's Car Gallery 112 05-21-2007 05:37 PM
noise on decel wizurd Transmission (AT/MT) & Driveline 5 04-04-2006 12:07 AM
noise on decel in 2nd and 3rd PerformanceAutoSolutions Tri-State Area Forum 6 11-28-2001 04:41 PM
