Old 12-15-2004, 02:37 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default What % of hp increase per psi of boost?
Is thre any way to figure this? Obviously low compression motors equal smaller % gains, but can go way up in PSI boost levels, while high compression motors have much bigger gain per psi, but cant climb as high without serious problems.
I am just trying to guestimate my hp at this stage, boosting the 2.2 1990 motor which has 9.5-1 compression, 6 psi at this stage, hopefully 8-9 psi by the time I dyno test this spring.
I normally estimate an increase of 7% per psi but this is for motors set up for boost, ie low compression motors. Just wondering if high compression motors give a noticeable increase % per psi of boost.
Old 12-15-2004, 03:32 AM   #2
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
One main thing you need to remember is that PSI is just how much pressure of air is being pushed, not the amount. I think that CFM would have a much greater effect. Without knowing CFM of the air (volume), you really couldn't get a good figure.
wrxpeed is offline   Reply With Quote
Old 12-16-2004, 02:15 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
yea its really wierd...when someone asks you how much boost you are running, it means absolutly nothing. A vf22 running 15 lbs of boost is going to be a hell of alot more HP than a td04 (stock wrx turbo) running 20.
IllNastyImpreza is offline   Reply With Quote
Old 12-16-2004, 03:58 AM   #4
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
lil advice: get somebody knows how to tune it, before u break it
imprezilization is offline   Reply With Quote
Old 12-16-2004, 04:02 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Hey red,
I was wondering if you had a picture of your injectors out of the car. I am still trying to compare the n/a reds to the turbo pinks.
Thanks,
Dustin
subiekid is offline   Reply With Quote
Tuners: how much hp increase per 1 lb of boost? Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-16-2007 05:26 PM
Wanna know what 32 PSI of boost @ 9000 RPM sounds like? zzyzx Off-Topic 36 12-15-2005 09:22 AM
What kind of HP with [email protected] PSI on STOCK motor Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-08-2002 12:19 PM
What has more hp 16.5 or 18.0 psi? phxscooby101 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-29-2002 07:31 PM
How much HP do you get from 1 PSI of boost? Scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 07-31-2001 01:18 PM
