Old 12-15-2004, 04:34 AM   #1
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Default High Low inpedance Injectors, Which EMS can do both?
Now i know this info is presented in a sticky in this thread, but, Im still not sure. Im wondering if its an old post.
anyways here are my ?s
are PE injectors high or low impedance?
can the UTEC control both high and low?
can the link control both high and low?
reason i ask is because i have PE 800s, and id like to keep them. I how ever and going with possibly the tec2 standalone, and i hear it only runs one of those types of injectors is there any truth to that?
jared nelson is offline   Reply With Quote
Old 12-15-2004, 06:57 AM   #2
happasaiyan
Member#: 37731
high
not without modification
i dont know
happasaiyan is offline   Reply With Quote
Old 12-15-2004, 06:58 AM   #3
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
thanks!
Old 12-15-2004, 07:50 AM   #4
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
with the link you need ballasts to drive low imped. injectors.
Geek Guy is offline   Reply With Quote
Old 12-15-2004, 07:53 AM   #5
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
ok well the goal is to stick with my pe 800s so i guess the link, the hydra, and a few others would do that.
Old 12-15-2004, 08:40 PM   #6
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Some advise: I run a Tec2, my frined and i found you can't run low IMP inj but you can get a resistor block from a elcipse from a junk yard and use the factory resistor pack and then they will work! no problems just saved $500 for injectors. And low imp inj are way cheaper than high IMP INJ
jeff22 is offline   Reply With Quote
Old 12-15-2004, 09:23 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
that is compleatly contradictory to every thing i have ever posted about the tec and what is in the tec manual
the injectos shiv sold with his kit were RC low imp that were only 3ohms
stock/high ~14ohms
low ~2-3 ohms
when i talked to the PE ppl at sema they told me that the PE side feed 550s were low.. i think the anwser to origional question is "both"
the tec will run both
don't buy a 2 save up some $$ and get a 3r
Old 12-15-2004, 11:43 PM   #8
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
email from electromotive tech support...
The Tec2 will run either, doesn't know the difference.
Electromotive Tech Support
this was my question...
can the tec 2 support low and high impedance injectors?
Old 12-16-2004, 08:43 AM   #9
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Well they say it doesent know the difference but the only way we got the car to push the injector was with the resistor packs.
We also thought the same about the injectors! Try it? Maybe your results will differ!
Old 12-16-2004, 01:52 PM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
where do we get the idea that the utec cannot drive low Z injectors? maybe older hardware platforms, but not the latest, at least according to these words to the contrary:
http://forums.nasioc.com/forums/show...ance+injectors
Old 12-16-2004, 08:20 PM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
stand alones: Element Hydra, Motec, Tec II, Haltec, AEM.........
That's it.
You might be able to place capacitors in line with the fuel injectors, but do you want to mess with probably the single most important part of your engine, fuel delivery.
Old 12-16-2004, 08:32 PM   #12
GameOver
Member#: 23145
2004 WRX STi
BLUE
Electrically youd want your injectors to be matched to whatever circuit theyre connected to. I wouldnt put any injectors in my car that dont match the stock one's input impedance as you can FRY the other end of the circuit!!!!!!
Simple transmission line basics : you want your 'load'/injectors to match the source
Whats the difference in performance to mess with injector's impedance ?????
GameOver is offline   Reply With Quote
Old 12-17-2004, 05:32 AM   #13
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
yeah i agree... i was asking because i was interested in running the tec2, and i wasnt sure if that would be allright with the pe800s i have. which i think are high impedance.
Old 12-17-2004, 10:02 AM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you would most definitely want to use RESISTORS, not capacitors, in this application. and the resistor mod trick would work just fine to limit max current flow.
this is not a transmission line, btw. there are clamping circuits already in place in the ecu to control flyback energy from the rapid dI created as the injectors pulse on and off. otherwise, they'd already be fried.
hth
ken
can i just gut the first cat for a stage 2 flash or must i do both? evol04gt Newbies & FAQs 16 08-18-2008 04:23 PM
high/low impedance injectors for hydra garagedefeat Other Engine Management 9 06-07-2007 02:29 PM
Hydra ems low impedance injectors sola71 Other Engine Management 4 05-22-2006 02:52 PM
Low Impedance Injectors & UTEC- Can They Work Together? VWGrk1 Engine Management & Tuning 11 12-21-2005 04:25 PM
High/Low imp injectors speed_freak27 Normally Aspirated with bolt-on Forced Induction Powertrain 14 05-04-2005 08:55 PM
