Old 12-15-2004, 05:00 AM   #1
boreas
Member#: 57078
Default question on 02 wrx jdm projector bulb size?
can anyone tell me what size of the bulbs is my 02 wrx jdm hid projector using?
any suggestions on which brand and k i should get for the best result??
boreas is offline   Reply With Quote
Old 12-15-2004, 09:38 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
H1s. I can recommend to not go with the el cheapo bulbs you see on eBay that have blue coatings to simulate the look of HID bulbs. Try the Osram Silverstars or Philips Vision Plus.
Hank3 is offline   Reply With Quote
Old 12-15-2004, 10:03 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
If they are the OEM JDM HIDs the bulbs are D2S. For best lighting results only use industry-standard D2S bulbs such as Philips or Osram which are 4100K. Avoid aftermarket HID bulbs.
Also if you truly want the best results from your JDMs, and don't want to blind other drivers (especially with HIDs), you'll need to open them up and modify the internal plates to correct the RHD beam pattern.
Old 12-15-2004, 10:21 AM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
Doh - I saw his thread title and assumed it wasn't HID. Thanks for covering for me Muld
Old 12-18-2004, 07:37 PM   #5
boreas
Member#: 57078
thanks for the input guys~!!!!!!!
Old 12-18-2004, 08:20 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
http://stores.ebay.com/AV-CompumiX-Xenon-Store
this guy often sells a hella / phillips 4100 d2s kit for $289. I got mine there
hybrid gti 2 is online now   Reply With Quote
Old 12-18-2004, 08:28 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
He shouldn't need a kit if he already has a complete set of JDM HIDs with the ballasts and wiring. From his post all he seems to be looking for is bulbs.
Old 12-22-2004, 07:45 PM   #8
boreas
Member#: 57078
yeah and the reason that i am replacing the bulb is the color of the beam turned yellowish.........any comments on that guys?
would the color of the beam fade or is something else?
Old 12-22-2004, 07:46 PM   #9
boreas
Member#: 57078
oh btw the projector is only used for least than 2yrs
Old 12-22-2004, 07:52 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
HID bulbs do change color sometimes. If this has happened you will need to replace the bulb.
Old 12-23-2004, 12:43 AM   #11
boreas
Member#: 57078
any idea where i can get a better deal for a pair of 6000k or above (on the web)?
the most ideal one for me is 120000k
waiting for your opinions~!
thanks guys~!
Old 12-23-2004, 04:14 AM   #12
garie
Member#: 26607
2002 wrx wagon
serious? that would be like dark blue light.....
garie is offline   Reply With Quote
Old 12-23-2004, 08:11 AM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Like I said, OEM HID bulbs are all 4100K. Which is what you should stick with if you want the maximum useful light output from those lights. Plus they must be D2S bulbs. Most that you will find will be 4100 0r 4300K. Why you think that 12000K would be ideal is beyond me, those would be almost useless.
Old 12-23-2004, 06:22 PM   #14
boreas
Member#: 57078
oh i just like the color of those 120000k
but since u guys are strongly objecting i will be reconsidering it
how bout 6000k if avaible
i dont' like those 4000k cuz they look kinda white so.....
Old 12-23-2004, 06:25 PM   #15
boreas
Member#: 57078
besides i live in an urban area and rarely go out of town using my ride so the color is the most thing that i concern.....hehee
Old 12-23-2004, 06:32 PM   #16
boreas
Member#: 57078
oh and another question..................(i know i know)..............
becuz wrx is running the DRL and the low beam in the same bulb, would the hid flick or dim when i put it on half pwr?(let's say the i have the light switch off and hand brake is released)
Old 12-23-2004, 11:23 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Yes 4100K is kinda white, that's the idea. Anything higher will have more blue content with less usable light and more glare, which should be of particular concern to you if you're in an urban area where you are more likely to be annoying oncoming drivers with those lights. More so if you don't modify the RHD beam pattern which I highly recommend that you do before using them.
As for the DRL question, when installing HIDs you MUST disable the DRL control module by the glovebox by unplugging it. You should also not connect the negative side of the ballasts to the headlight switched ground circuit, but directly to chassis or battery ground.
Old 12-24-2004, 09:11 PM   #18
boreas
Member#: 57078
as for the RHD beam pattern i have already done that
but i couldn't find the neg for my ballast can u provide some more info on that, cuz the whole thing came in with the plug and play harrness
Old 12-25-2004, 12:55 AM   #19
Hank3
Member#: 16157
'03 Mazda P5 <><
With HID bulbs, ~100 hours is needed to fully colorshift - also referred to as "burn-in" most of the yellow will be gone before that. After that, you begin the purple-ing and blue-ing.
FS : 02 wrx JDM projector HID headlight boreas Exterior/Styling 15 09-01-2007 08:46 AM
FS: 02/03 JDM Projector (non-HID) headlights, stock 02/03 WRX tail lights, more Dakken Tri-State Area Private Classifieds 12 06-28-2007 09:15 AM
Pic Request-02 WRX JDM projector wiring help!! vicdeng Electrical & Lighting 9 11-08-2006 03:21 PM
"Subaru" nameplate question on 02+ WRX gould9184 General Community 2 06-17-2006 11:24 PM
Brighter/Better Bulbs to replace JDM Projector Bulbs KanosWRX Electrical & Lighting 10 08-31-2003 12:40 PM
Message Board Statistics All times are GMT -4. The time now is 10:48 PM.
