Old 12-15-2004, 04:06 PM   #1
Dm0n3y002
Member#: 73407
Default Knocking on cold start-up
Well the temps have diped below freezing and my engine is now making a knocking sound untill it is wormed up, after sitting overnight. I have herd that this is normal, which is weird to me, but can someone take a sound clip of there engine after sitting overnight in freezing temps. If u could rev it alittle too that would be cool, just want to compare sounds. Thanks.
Dm0n3y002 is offline   Reply With Quote
Old 12-15-2004, 05:22 PM   #2
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Do you have a catless uppipe? Since installing my helix up and ic hoses, I have noticed that same noise --has a kind of vw diesel sound, right?? I figured I had a leak somewhere becuase I don't remember hearing any noises like that from last winter --but my memory isn't too great either.
kuks is offline   Reply With Quote
Old 12-15-2004, 05:48 PM   #3
wrbwagonguy
Member#: 62625
I've got something similar. Nothing I would be too worried about, unless it get really loud. Just drive gently untill you are up to normal operating temps.
wrbwagonguy is offline   Reply With Quote
Old 12-15-2004, 06:05 PM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The ticking noise on cold starts is pretty common... usually lilfter noise, and is a characteristic noise on Subaru opposed 4 cylinder motors.
/Andrew
Kha0S is offline   Reply With Quote
Old 12-16-2004, 01:16 PM   #5
Dm0n3y002
Member#: 73407
I didnt says ticking, knocking. Sounds like piston slap.
Old 12-16-2004, 01:23 PM   #6
b0dh1
Member#: 35269
2011 WRX
Roger that! I had the same noise the other morning. Scared the jeepers outta me.
b0dh1 is offline   Reply With Quote
Old 12-16-2004, 01:35 PM   #7
codered
Member#: 58033
2008 Forester Sports
Pure White
Me too! Only does it right at start up and then I dont hear it anymore. Gives me a bad feeling deep inside my tummy!!
codered is offline   Reply With Quote
Old 12-16-2004, 01:46 PM   #8
Aspenbullet
Member#: 71240
2002 WRX Cobb Stg II
Aspen White w/Yakima Rack
Default Same sounds at startup too.
I hear the same kind of slapping/knocking but only at start-up also. I was also wondering if it could be a tiny leak at the up pipe that goes away as the metal starts heating up. My friend with the same setup as I do has a small up pipe leak and it's sound is a bit more distinct than the slap/knock I think we are describing.
I'm hoping/thinking it's normal.
Aspenbullet is offline   Reply With Quote
Old 12-16-2004, 01:52 PM   #9
dmastropwrx
Member#: 40509
2011 WRX Sti
red
AHhhh I was just wondering when i was going to see a thead pertaining to this topic. Yeah its common i thought my engine was goign to slap itself silly yesterday night. Its normal just dont boost until ur oil temp is up to operating speed. Hence the major reason why i got an oil temp gauge.
dmastropwrx is offline   Reply With Quote
Old 12-16-2004, 02:07 PM   #10
aaronyoung
Member#: 73087
2002 wrx
acusump!
aaronyoung is offline   Reply With Quote
Old 12-16-2004, 03:51 PM   #11
Dm0n3y002
Member#: 73407
Somone get some sounds clips, lets compare sounds haha. Ill get a clip tomorrow.
Old 12-16-2004, 06:16 PM   #12
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Probably Piston slap.. you should hear my motor with Je pistons it sounds like a galloping horse sometimes until it's at operating temp.
Also my stock ej205 had some cold weather/starting piston slap and valvetrain noise also, i dont think its anything to worry about. Just take it easy until your oil temp. is up.
PaulRex is offline   Reply With Quote
Old 12-16-2004, 11:12 PM   #13
Dm0n3y002
Member#: 73407
Galloping horse
Old 12-16-2004, 11:41 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....d00ds....these engines make all sorts of noises that most other engines don't.....and the cold start noise is, indeed, piston slap and it's been happenin' to flat subie engines for a LONG time, now.... No worries m8's
Old 12-17-2004, 12:06 AM   #15
yergi
Member#: 65303
nope nope
"dooby specialist"
you guys sure that your oil filters have that flow valve in them that prevents the oil from seeping back down from the block when the engine is turned off?
stop being cheap, trying to save that extra dollar when buying filters.
Your rex would thank you.
-Yergi
yergi is offline   Reply With Quote
Old 12-17-2004, 01:23 AM   #16
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
The subaru filters are upright
mr2guru is online now   Reply With Quote
Old 12-17-2004, 08:12 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and at the very bottom of the whole damn thing, too
Old 12-17-2004, 08:41 AM   #18
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Also consider running a 0W synthetic oil in the winter.
WolfPlayer is offline   Reply With Quote
Old 12-17-2004, 09:20 PM   #19
Dm0n3y002
Member#: 73407
-Yergi
Old 12-17-2004, 09:28 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
I wouldn't do that unless it gets VERY cold where you are....5w30 M1 is so thin that it pours like water as it is....
Old 12-17-2004, 10:38 PM   #21
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I try to tell people 5W-50 for the car but everyone thought I was nuts!! Next time take my advice STi oil isn't 5W-50 for no reason!!!!
DuoMaxwell is offline   Reply With Quote
Old 12-17-2004, 10:49 PM   #22
MRF582
Member#: 48219
. Always drive
the race line .
well, 0W-10000000000000000000000000000000000000 would be the best oil there is. i use 15W-50 when it's not feezing outside and 5W-30 when it is freezing outside and i have to visit my folks in Pennsylvania in december. if i didn't autoX or track my car, i would probaly use 10W-30 or 5W-30 all year round.
MRF582 is offline   Reply With Quote
Old 12-17-2004, 10:54 PM   #23
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Mine does the same thing. Its just piston slap. They all do it when it's cold out....
Obsessive is offline   Reply With Quote
Old 12-18-2004, 12:55 AM   #24
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I just changed my oil tonight put in some Mobil1 5w/30, didnt stop the knocking at all but it was noticably smoother since i havnt changed my oil in 5k and i was using cheap castrol stuff. New Mobil1 Oil smells pretty good but new tranny fluid makes me want to vomit
Old 12-18-2004, 01:03 AM   #25
WolfPlayer
Member#: 65054
2005 STI (CGM)
0W-40 Mobil 1
t
Rod knock on cold start blitzmr2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-19-2008 10:38 AM
Brake / Clutch Knock Noise on Cold Start -AliasMunky3- Brakes, Steering & Suspension 1 01-25-2005 02:00 PM
"Knocking" on cold start-up Blue_Rexer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-01-2004 11:56 AM
Knock with cold start jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-26-2003 12:53 AM
