Old 12-15-2004, 04:57 PM   #1
Whit
Member#: 11548
'02 OBS
Default Dim hi-beam indicator, when on low-beams...
2002 Forester, gf's car, was in a small wreck a year ago had to replace right front fender, headlight assy., fog lamp, hood, etc. No wiring was replaced.
Last month the right side low beam headlamp went out, I figured the bulb was bad. Nope, turns out the electrical socket that plugs onto the bulb had melted, badly.
It had been over a year, so the body shop gave her the run-around on warranty, she took it to a dealer, they said to go to a parts store and buy a new socket. If it were me I would have b1tched about the 3/36 warranty which it's still under, but she's wants to be independent.
So I bought a new socket for the bulb and soldered it into place. The lights seem to work fine now, *except* the hi-beam indicator on the dash glows dimly when the lights are on low-beams. I don't remember this happening before and it doesn't happen on my '02 OBS.
Is this normal or did I do something wrong?
Thanks!
Whit is offline   Reply With Quote
Old 12-15-2004, 05:20 PM   #2
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
Did you accidently solder the wrong wires together...thats what i did when mine melted
The wires are different on each side of the car. I used the other side as reference when i did mine. You should check the old socket to make sure you didn't solder the wrong wires together.
fasterthanrayswrx is offline   Reply With Quote
Old 12-15-2004, 05:46 PM   #3
Whit
Member#: 11548
'02 OBS
I'm about 93% sure I did it right, I had the melted socket there as a reference when I did the job. I wouldn't think it would work "properly" if I'd have crossed some wires, but...
Faint high beams indicator stays on feropont Electrical & Lighting 9 04-08-2006 12:12 PM
noob on low beam light bulb chanyeehon Electrical & Lighting 14 12-11-2005 06:24 AM
Glowing high beam indicator when headlights are dimmed bandrews Newbies & FAQs 0 07-15-2005 11:33 PM
HELP: HID only comes on when on high beam? datdudedennis Electrical & Lighting 1 04-12-2004 12:52 AM
How to make high beams work independantly of low beams? Imprezer Interior & Exterior Modification 13 10-30-2001 10:02 PM
