Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 12-15-2004, 05:33 PM   #1
MattSTi
Member#: 54885
2004 PSM STi
91 Spec Miata
Question Tapping Manifold for EGT sensor
I just ordered Turboxs' EGT sensor setup (same as the EGT sensor kit for DTEC) for my Tuna Pro. I figured that I might as well get this out of the way when I'm doing the Tuna install, and it's a necessary tuning tool.
I've gotten a pretty good idea of what is involved in the actual tapping of the manifold by reading other threads but I have few questions that I would like to clear up.
1. Is it correct that I only need to remove the drivers side manifold, not the cross over pipe, etc.?
2. Should I replace the manifold gasket, and if so, does anyone have a PN for this gasket. Is this the right one? - http://subydude.com/parts/details.php?603
3. Do I need any tools other than
-Drill
-Vice
-Bit
-Tapping bit
5. At what angle should the EGT sensor be installed?
Thanks a lot, any info would be greatly appreciated.
-matt
MattSTi is offline   Reply With Quote
Old 12-15-2004, 05:46 PM   #2
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
-Drill
-Vice
-Bit
-Tapping bit
-matt
1. correct.
2. remember to replace the manifold to block gasket and the manifold to crosspipe gasket.... it looks like the same as the up pipe but it is not. i got mine from rallysportdirect. talk to ben he can get you the correct ones.
3. grinder, or metal file to get your threads flat on the outside of the manifold. cutting oil, tap handle, some sort of cutting tool to trim your heat shield, safty glases.
4. you dont really have much of a choice. i'd say drill into the casting button as close to 90 deg as possable...
DISCOPOPE is offline   Reply With Quote
Old 12-15-2004, 05:53 PM   #3
MattSTi
Member#: 54885
2004 PSM STi
91 Spec Miata
Thanks a lot discopope, that was very helpful.
If possible, could you outline the actual tapping process from drilling to threading the hole?
Also, what size drill bit will I need in relation to the Tap?
Thanks again
-matt
Old 12-15-2004, 06:11 PM   #4
Trevor723
Member#: 57989
2011 F150 EcoBoost
flame blue
To start, get something to prick the manifold in the center of the casting dot. Next use some varying sized drill bits to make the hole. I used like 1/8", 1/4", and finally 21/64" which is the size required for a 1/8NPT tap. Now you just need to thread the tap slowly into the hole until it bottoms out. Slowly back out the tap and voila, there's your threaded hole.
Trevor723 is online now   Reply With Quote
Old 12-15-2004, 07:02 PM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
FWIW
Unless TurboXS has done a very recent change the thread you just described now doesn't work with a TurboXS EGT probe. You require a 10mm x 1.25 Tap and use an 11/32 drill.
Wombat North is offline   Reply With Quote
Old 12-15-2004, 07:05 PM   #6
Trevor723
Member#: 57989
2011 F150 EcoBoost
flame blue
Ah sorry. Should have mentioned that I used Defi probe.
Old 12-16-2004, 02:26 AM   #7
Pirana
Member#: 55197
Subaru Stars
any pics...
Pirana is offline   Reply With Quote
Old 12-16-2004, 02:27 AM   #8
Pirana
Member#: 55197
anyone info
Old 12-16-2004, 02:47 AM   #9
Trevor723
Member#: 57989
2011 F150 EcoBoost
flame blue
Very nice post!
Old 12-16-2004, 03:30 AM   #10
MattSTi
Member#: 54885
2004 PSM STi
91 Spec Miata
AWESOME! Thanks a lot man, that helps so much.
-matt
Old 12-16-2004, 10:04 AM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....do not 'bottom' the tap.....tap just deep enough for the collar to seat and done.....
Old 12-16-2004, 02:12 PM   #12
Wombat North
Member#: 21267
STI, EWG 8cm Green
My post before maybe wasn't clear enough. The thread on the TurboXS probe is 10mm dia x 1.25pitch x 16mm long. It is a "straight" thread not tapered.
Old 12-16-2004, 03:35 PM   #13
DISCOPOPE
Member#: 43339
2oo4 STi
also, just because i know 'someone' who did this.
mark the side of the manifold to drill with a marker or crayon before you take it off..
sucks to know you just spent 30 min tapping the wrong side....
Old 12-16-2004, 04:15 PM   #14
paperchasin
Member#: 57117
2004 STi
Great writeup!!! I vote for FAQ!!!
paperchasin is offline   Reply With Quote
Old 12-16-2004, 04:40 PM   #15
MattSTi
Member#: 54885
2004 PSM STi
91 Spec Miata
"The base should fit tight and have at least 1/8" visible" vs. "Tap just enough for the collar to seat"
What's the reason for leaving some of the thread visible?
I definitely think this is FAQ material.
Old 12-16-2004, 05:15 PM   #16
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
It's FAQ approved! However this should probably be moved to the Electrical & Lighting forum for the best viewing. Pirana, you should also submit this to www.scoobymods.com as well.
Old 12-16-2004, 07:39 PM   #17
Wombat North
Member#: 21267
STI, EWG 8cm Green
Seems you guys like pictures
Below is a TurboXS EGT probe that has the 10mm thread. Since everyone wants to use a 1/8"NPT tap to do it you will need/can do this.
By doing this you can go back to useing most EGT probes as they are usually 1/8"NPT or you can upgrade to the TurboXS probe without messing up the 1/8" NPT hole you had.
Old 12-16-2004, 10:32 PM   #18
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Tapping the hole just deep enough so that the probe tip is in the middle of the manifold is the reason, here. Tap too deep and the probe tip gets too close...or even touches .... to the far side of the manifold........BAD JUJU
Old 12-17-2004, 12:53 AM   #19
WolfPlayer
Member#: 65054
2005 Grannymobile
Hitch + Block Heater
I just ordered the Manifold to Head gasket and the Crossover Pipe Gasket. Here are pics along with part numbers:
http://www.bescaredracing.com/sti/exhaust/soa/gaskets/
WolfPlayer is offline   Reply With Quote
Old 12-18-2004, 01:02 PM   #20
Pirana
Member#: 55197
My reason is if you go too far, it can stay loose since threads will be wider than the nipple and it cant go farther down. This is the way we have been doing them on our heavy duty equipment at work for ages.
Old 05-15-2007, 10:50 PM   #21
LuvJuggs
Member#: 113807
I have a catted Helix Downpipe with an o2 bung (used by stock sensor) and a bung in the bellmouth. I have a egt probe i want to mount here anyone know what the thread size in this bung is?
Thanks
LuvJuggs is offline   Reply With Quote
Old 05-15-2007, 10:51 PM   #22
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks
waste of time
Old 05-18-2007, 03:49 PM   #23
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
OMGHi2U
drill the manifold making sure you have a perfectly steady working surface. A drill press would be ideal, much better than an hand-held drill
Then use a tap with the handle to thread it.
During tapping, make sure you use cutting oil and reverse the tap direction a 1/2 turn every few revolutions to break up the ships that are stuck between the teeth.
and assemble
Its not hard if you know what to do.
CLEAN EVERYTHING OUT OF THE PIPE BEFORE INSTALLING!!!!!!!!!!!!!!!!
~Chris
WRXDriftR is offline   Reply With Quote
Old 05-25-2007, 07:29 PM   #24
josh06wrx
Member#: 136998
06 30R STi
sweet, that pic says it all! thanks
josh06wrx is offline   Reply With Quote
Old 05-26-2007, 03:57 AM   #25
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
perfect...i think i can handle this!
thanks for the info
Shops for tapping manifold for EGT mpggomd New England Impreza Club Forum -- NESIC 6 03-01-2008 01:51 PM
possible to drill/tap stock exhaust manifold for egt? ponamy Alaskan Impreza Club Forum -- AKIC 4 07-29-2006 02:04 PM
WTB: Tapped Manifold for EGT Probe ScoobySnacker Private 'Wanted' Classifieds 5 05-22-2006 07:26 PM
Tapping manifold for egt Mighty Mouse Factory 2.0L Turbo Powertrain 12 09-18-2002 11:36 AM
tapping the manifold for EGT guage = dead warranty? ants wrx Warranty Issues & SOA Problems 2 07-19-2002 04:06 PM
Message Board Statistics All times are GMT -4. The time now is 04:43 PM.
