Old 07-04-2001, 02:44 PM   #1
Jimmy
Member#: 586
Default how do install a walbro fuel pump
I have the pump..
the fuel pump iam using is a walbro
I got to the gas tank and took the old on out..
Do just plug the pump in and clip all the lines to it, i did this
the old pump has this net type filter on it do i reuse this or not?
Because the pump i have there no place to use the old net...it has a filter in it i think
does any body know ????
Jimmy
Jimmy is offline   Reply With Quote
Old 07-04-2001, 03:31 PM   #2
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Fuel pump install
There should be a fuel filter sack on the end of the new pump, too.
blaster88 is offline   Reply With Quote
Old 07-04-2001, 04:06 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Instead of twisting it around to get it out, I suggest you just remove the single screw that holds on the float assembly to the main bracket - but be VERY careful not to drop it in the tank. That'll make it 700 times easier to get out.
how do you test a fuel pump relay fyr3 Newbies & FAQs 2 04-04-2013 05:38 PM
How to install injectors and fuel pump? Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-25-2006 12:28 PM
Installing a Walbro fuel pump in a 04 WRX hMinus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-23-2006 07:45 PM
I'm having trouble installing a Walbro fuel pump, need help. porque Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-14-2006 10:54 PM
install a Walbro fuel pump without any other changes? nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-05-2002 11:47 AM
