Old 12-16-2004, 12:47 PM   #1
409Industries
Member#: 55553
2001 Impreza 2.5RS
Default Apexi TT, need some clarification
hi, i did a search and came up with a lot aready on the topic... so sorry if im already beating a dead horse, i just need some quick clarification.
Installed my apexi turbo timer, its working fine. I just need to double check what wires to cut so that i can use the factory door locks while the motor is idling and the timer is counting down.
heres what i found. does anyone have a pic that shows which wire to cut? the one in this old link is broken:
http://forums.nasioc.com/forums/show...=301643&page=1
- Once the TT is installed and working you will have the following problem; While the TT is counting down the Factory Alarm will NOT arm and the doors will NOT lock when you press the keychain "Lock/Arm" button.
To fix:
1) Locate the Keyless Entry Module above the fuse box on the drivers side of the car (you should already have the under-dash taken apart by now so the Keyless Entry Module is directly above the fuse box.) Unscrew the nut and pull back the tape covering the wires. There are two GREEN wires both have BLACK stripes on them. You need to cut the DARK GREEN W/ BLACK wire. Cut it and taped both ends. Retape the bunch of wires and screw the Keyless Entry Module back into place.
Secondly, i dont think my 04 STi has a factory alarm, i didnt see any module in the center console by the ebrake, is it behind my glovebox? whats a good way to see if i have an alarm... bump my window or kick my tires? i think i just have factory door locks.
Thanks for your help everyone.
409Industries is offline   Reply With Quote
Old 12-16-2004, 01:27 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The alarm module is behind the glovebox in your STi if you have it. It is an option so not all cars are so equipped. Also if you have the alarm there will be an alarm horn in the engine compartment, on the passenger side strut tower. Further when you arm/lock it the parking lights will flash, and the "Security" light on the dash will blink until you disarm/unlock. Depending on how the sensitivity of the shock sensor is set, the alarm should go off from a hard impact to the car. An impact below the full alarm threshold will trigger a pre-alarm warning chirp, then a harder impact will trigger a full alarm.
Old 12-16-2004, 08:17 PM   #3
409Industries
Member#: 55553
2001 Impreza 2.5RS
ok, yeah i saw the "alarm bracket" on the strut tower. I thought that was a horn at first. so looks like i need to deal with the factory alarm too.
Plainly stated. can someone hook me up with some pics on which wires i need to cut so that i can still use my remote to lock / arm the alarm while my TT is counting down? i dont want to screw it up.
TIA.
Old 12-20-2004, 01:55 PM   #4
409Industries
Member#: 55553
2001 Impreza 2.5RS
*bump*
need some clarification.... reality1011 Normally Aspirated Powertrain 14 05-14-2006 06:19 PM
Need some clarification.... reality1011 General Community 2 05-09-2006 01:09 AM
I need some clarification. Scubiesteve25RS Normally Aspirated Powertrain 2 01-04-2006 08:00 AM
Need some clarification on brakes! HiFiWRX Brakes, Steering & Suspension 8 09-09-2004 03:57 PM
Auto-X rule summary thread coming soon, need some clarification from experts! TheWRX Motorsports 5 04-14-2002 10:21 PM
