Old 12-16-2004, 04:15 PM   #1
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default How do i replace this light?
the emergence signal light in my dash board went out....how do i replace it?
~Leor
WRC1 is offline   Reply With Quote
Old 12-16-2004, 04:45 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You'd have to remove the switch to access the bulb. AFAIK it is replaceable.
Old 12-16-2004, 04:52 PM   #3
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
how do i pull off the switch
Just stick a flat head under the bottom and jiggle it out?
~Leor
Old 12-16-2004, 06:07 PM   #4
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Based on switches I know on the GD & SG, it is very likely that there will be 2 tabs pointed to the left & right. If you want to try the flathead screw approach, my suggestion is to try on one side, thereby releasing one tab at a time.
I'd feel more comfortable removing the stereo trim underneath to expose the tabs from the bottom back side, then using pliers to push the tabs inward. That's what I usually do on my Impreza & Forester.
satrya is offline   Reply With Quote
Old 12-16-2004, 06:27 PM   #5
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Sounds good Ill do that then, thanks.
~Leor
How do you replace the parking light switch? Bobert540 Electrical & Lighting 2 10-14-2007 10:09 PM
How do I remove this wall light from my bathroom m750 Off-Topic 16 08-17-2006 09:21 PM
How do I replace '02 fog light? AndrewJMarshall Electrical & Lighting 5 11-07-2005 08:53 AM
How do i replace a light in my dash? WRC1 Electrical & Lighting 1 10-13-2004 05:45 PM
How can I replace this light lens? Ripper Interior & Exterior Modification 4 11-06-2001 01:06 AM
