Old 12-16-2004, 06:18 PM   #1
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Default Anyone here using the Spoon Ground Voltage Stabilizer?
I saw this on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33577
and thought it might be a nice addition to the car to help supplement the grounding kit. This item kinda sounds like it does the same thing as a power capacitor on a car stereo system. Is this thing worth buying?
ScoobyNubieToo! is offline   Reply With Quote
Old 12-16-2004, 06:22 PM   #2
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
As far as I know it is just a CAP. So I would say If you allread have a CAP for your stereo then this will do allmost nothing.
AFBeefcake is offline   Reply With Quote
Old 12-16-2004, 06:27 PM   #3
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
I don't have a cap, but even if I did that would only affect the stereo equipment not the whole car's electrical system, right?
Old 12-16-2004, 06:31 PM   #4
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Ether way you put the cap across the battery. weather its in the tunk or under the hood its still one side of the cap to positve and the other to ground. Yes from the engine and computer it wound be beter to have the cap as close to the battery as posible. The more wire the more voltage drop.
Old 12-16-2004, 06:31 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Waste of money. Your car already has a voltage stabililzer, it's called a battery. There is also the voltage regulator in the alternator.
Spend a few bucks and add some extra grounds to your car if you like, it can't hurt although you shouldn't expect magic results. If you have a high-power stereo or other accessories you can upgrade the main engine and chassis grounds, and alternator output wire, for beefier ones. But don't bother buying a commercial grounding kit or anything like this "stabilizer".
Old 12-16-2004, 06:36 PM   #6
V6
Member#: 2703
Y2K GC8
Silver forever
I think its the same as the Sun Automobile's Hyper Voltage System.
V6 is offline   Reply With Quote
Old 12-16-2004, 06:45 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Probably. Someone had one of those here in the Classifieds a few months ago, nobody wanted it.
Old 12-16-2004, 06:46 PM   #8
5spdfrk
Member#: 46407
blew
Spoon doesn't make a product like that, and if they did it would be for honda/acura. Not for anything else. Ha, amazing! I can't believe they are using Spoon's name.
Do what mulder said, get some 10ga. wire, ground a few extra places, and be done w/ it.
5spdfrk is offline   Reply With Quote
Old 12-16-2004, 07:07 PM   #9
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
True but the seller listed it under other cars since it's kinda of got a universal application that makes it compatible with other makes/models of cars.
Old 12-16-2004, 07:12 PM   #10
V6
Member#: 2703
Y2K GC8
Silver forever
Seems like all the products the seller selling are not the real thing.
Just like those seats, all are the same except the stitching is TRD or Mugen, etc...
So I think this Voltage Stabilizer is just those copy cat products that stick on the Spoon badge to fool you.
Old 12-16-2004, 07:16 PM   #11
5spdfrk
Member#: 46407
blew
True, but he is using a well known, respectable name in motorsports to sell his product. I would never buy from someone like that.
Old 12-16-2004, 10:31 PM   #12
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Don't waste your money on a riced up capacitor. A capacitor is used to remove the variations in voltage from a dc source. A filter of sorts. They work by storing a small amount of charge that can be stored or released quickly to stabilize voltage. The voltage in you cars electrical system doesn't fluctuate quickly enough for a capacitor to make a difference. The reason they are used in car audio is to provide stabilization to a system that changes it's power requirements rapidly. The amp for you subs like a cap the most as it's power drain varies wildly when the bass hits. And the cap crammed in that little voltage stabilizer would be 1/4 farad or so. Not enough to dampen the only surge draw in a standard electrical system, the AC pump. Spend the money on a DIY ground kit. It has more tangible results, but nothing magical there either. The battery is a suffecient voltage stabilizer for the constant stable draw of the cars electical system.
phantomsr is offline   Reply With Quote
Old 12-17-2004, 01:30 PM   #13
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Sounds like the best explanation so far...
Has anyone here used this Safety Devices Roll Cage kit(s) for the GC? Racer5 Motorsports 12 04-07-2005 07:21 PM
Has anyone here used this Safety Devices roll cage kit for the GC? Racer5 Interior & Exterior Modification 6 04-04-2005 04:08 PM
Anyone here using the K40 laser defuser? Jayhawker Car Audio, Video & Security 2 02-05-2005 11:35 AM
Anyone Using the Koni / Ground Control Combo D_REX Motorsports 44 07-31-2004 12:48 PM
OT-Anyone here use priceline.com for gas? Impresario General Forum Archive 2 08-26-2000 08:08 AM
