#1 |
Member#: 56425
NESIC
Vehicle:2002 WRX Aspen White |
Well as I found out in the Silverstar thread, I am not capable of getting Osram Silverstars for my 02 WRX with the 9007 bulb size. I have found myself foglight bulbs to replace my burnt stockers, but improved headlight bulbs are also on my list. So I ask, since I cannot get the Osrams, what is the best bulb with actull useable light performance for 9007 bulb size. Oh and a website or recommendation as to where to get them would be much appreciated! Thanks alot.
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
You can get Sylvania Xtravisions in most parts stores. They may not have the output of the Osrams but should be somewhat better than stock bulbs. Unfortunately there aren't that many options for truly upgraded lighting with the 9007 configuration, most of the aftermarket bulbs available are the blue-coated "superwhite" or "HID look" type that look brighter but aren't.
#3 |
Member#: 2703
Vehicle:Y2K GC8 Silver forever |
you can try the GE night hawk (which claims to be up to 30% more vision on the road and the road signs) and if you have a bit more money to spend, get a set of wiring harness kit for 9007 then you will benefits from them.
#4 |
Member#: 56425
NESIC
I can do both. I saw the Xtravisions and I am gonna look up the GE Night Hawk as well as the wiring harness. Thanks for the advice. Mulder you have been especially patient and kind thanks for the help, its been much appreciated!
#5 |
Trust no one
Yes a harness may also be helpful, but only if it addresses the voltage drop on the ground side which is the weak link in Subarus. The drop on the positive side isn't that much, but the loss through the switched grounds is considerable. If you install a harness that uses relays to directly switch the bulbs to ground, or make one yourself, there should be a noticeable improvement in light output with whatever bulbs you decide to use, even stock ones.
#6 |
Member#: 25323
Vehicle:2003 WRX Wagon Black |
If you want a stock voltage lightbulb, get the Philips Hi-Visibility bulbs. An extensive test by gtguy appears here:
http://forums.nasioc.com/forums/showthread.php?t=303370 I've got 'em and I love 'em. |
#7 | |
Member#: 59068
NWIC
Vehicle:2005 Impreza WRX STi Blue |
Can you reccomend a harness for OEM '02 WRX 9007 headlights? I did look at SUVlights.com, but they seemed to have 4 relays. Would 2 relays be enough?
I'm not looking to craft my own. -Will Quote:
#8 | |
Member#: 31511
SCIC
Vehicle:03 GD2 95 GM4 www.ITNRally.org |
#9 |
Member#: 22035
SCIC
Vehicle:2008 STI White |
yea, two relays would be enought. thats all i use, and i have gone up to 100w lights in it with out hurting the harness
Shane |
| Thread Tools | |
| Display Modes | |
| HID bulbs - 6000k temp - 9007 bulb fitment | FuelCutOff | Private 'For Sale' Classifieds | 3 | 01-17-2005 06:03 PM |
| EuroLights 65/100 9007 bulbs FS... | gtguy | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 10-30-2001 01:32 PM |
| Brightest/whitest 9007 bulbs you can buy? | SK00Impreza | Interior & Exterior Modification | 3 | 10-25-2001 08:30 PM |
| best place to buy xenon 9007 bulbs | REDOO2000 | Interior & Exterior Modification | 1 | 10-22-2001 11:22 PM |
