Old 12-16-2004, 06:46 PM   #1
SonicSubie03
Member#: 50622
2003 SonicYellow
Brighter, Louder, Faster
Default HELP!!! Headlights...
<Back ground>
I have the cheapO Ebay JDM head light jobbers. I got them used from Tad(maybe u can help me if you see this), they were all wired up with the "Blue Plug" and worked great. From washin the car in the cold so much some of the wires may have froze and cracked. The headlights are all messed up. Low beams are hay wire, hi beams done work, yadda yadda.
<Problem>
Can someone hook me up with a wire diagram of the way they should be wired and connected to the blue harness. I don't care if you draw it in paintshop. I need to re-wire these before i make my 5 hour drive home for the holidays, HELP!
-Pat
SonicSubie03 is offline   Reply With Quote
Old 12-16-2004, 07:52 PM   #2
SonicSubie03
Member#: 50622
2003 SonicYellow
Someone Help....
-pat
Old 12-16-2004, 08:31 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
do you still have your factory headlights?
Old 12-16-2004, 08:38 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Was the info I posted for you in Tri-State of no help at all?
Old 12-16-2004, 09:10 PM   #5
SonicSubie03
Member#: 50622
2003 SonicYellow
nope, i need some sort of diagram.
-Pat
Old 12-16-2004, 09:23 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Why, the wiring on those lights is ridiculously simple. They have no relays or anything, just bulbs and wires. As long as you can identify the commons and low/high beam wires you can put it all back together.
Old 12-16-2004, 10:28 PM   #7
SonicSubie03
Member#: 50622
2003 SonicYellow
right, thats the problem. A, the existing wires are all the same color. B, they are all messed up/braded together. C, i don't have the OEM lights out here at school w/ me to follow the way they go.
So your sayin both hi and low share a common power, but have their own grounds for switchin on and off?
-Pat
Old 12-16-2004, 10:33 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
-Pat
Yes, the Subaru headlight system is common power, switched ground. As I said in the other thread the center pin on the blue connector is the common positive, the two bulb commons should be tied to that. The other wires are the switched grounds.
Old 12-17-2004, 04:29 PM   #9
SonicSubie03
Member#: 50622
2003 SonicYellow
ok, i'm gonna rip'em out and try to re wire them this weekend...
thanks
-Pat
Please help! Headlights go On and Off... byan Legacy Forum 3 06-10-2003 03:22 PM
need help! headlight removal ton1179 Interior & Exterior Modification 9 11-13-2002 04:03 AM
Help- headlights out philo2g Newbies & FAQs 1 08-19-2002 05:17 PM
Help!!!HEadlight prob s-one Mid Atlantic Impreza Club -- MAIC 2 07-16-2001 05:12 PM
