Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 12-16-2004, 07:33 PM   #1
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default 2004 STI has a dead instrument cluster: help!
This is my roommate's STI - he called and told me his instrument cluster is dead. Not just the illumination, but all the needles, indicators, etc. His AVIC-N1 is still displaying the speed (which it reads from a wire tapped to the ECU) but it'd be great to be able to see the gauges working again soon.
He said he pulled the fuses and they all looked good - He has not tested each fuse with a multimeter yet though. I know in the past I've had "good" fuses that were not good and the only way I found out was with a multimeter.
Anybody have this problem before? I checked the FSM and it wasn't very helpful. Under the diagnostics for the symptom (Combination meter does not operate), all there was was "Ground" and "Power Supply". Some guidance on a likely culprit would help.
Thanks
-nick
nhluhr is offline   Reply With Quote
Old 12-16-2004, 09:19 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if the meter is completely dead, it almost has to be a power issue, right? follow the harness (should be harness c the one with 10 pins in a single row) back from the meter - maybe it got pinched and the power lead cut - either that or a ground wire.
Old 12-18-2004, 03:48 AM   #3
Mumbles
Member#: 248
Has he ever taken the cluster out? If not check the fuses again, switch similar amped ones around, alot of times a blown fuse is hard to see.
-B
Mumbles is offline   Reply With Quote
Old 12-18-2004, 04:01 AM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah that's what I've told him but he hasn't done it yet.
2004 Sti Hydra EMS II 2.6 ECU SOLD tolishel Engine/Power/Exhaust 8 07-07-2010 04:50 PM
FS : (MO) 2004 STi - Aspen White 47k Miles - 55 Photos - SOLD balzak Private Vehicle 'For Sale' Classifieds 54 06-22-2010 10:10 AM
FS : (OH): 2004 STi six speed transmission/axles/R180/driveshaft/clutch/flywheel coolblue05 Drivetrain 15 06-21-2010 07:31 AM
WTB: 2004 STI instrument cluster(has to be 04 STI one) Skullyg VIC Private Classifieds 1 05-27-2010 11:09 PM
Just installed VF22 on the STi has a coolant leak...please help ioeth Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-24-2008 10:53 PM
