Old 12-17-2004, 05:53 AM   #1
mistaboosta
Member#: 68722
Default Rotora and Stoptech BBKs in stock WRX rims?
Would the rotora BBK (330 x 24 mm discs) or the Stoptech BBk (328 x 22 mm discs) fit into the stock 2004 WRX 17inch rims ? ?
Last night I was in my buddy's car and he has the stock STI Brembo's with Brembo drilled rotors and Feredo 3000 brake pads. The braking power was amazing. Would I get something similar to that with the above BBKs???
mistaboosta is offline   Reply With Quote
Old 12-17-2004, 06:45 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You mean the stock WRX STi rims? The Stock WRX rims are 16". If you mean the STI BBS wheels, then yes, they'll fit.
Old 12-17-2004, 07:00 AM   #3
garie
Member#: 26607
2002 wrx wagon
^^ wat he said
garie is offline   Reply With Quote
Old 12-17-2004, 02:02 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
If you are talking the 16" rims then no, they won't fit. Try the TWR BBK for those. They make a 16" kit.
Arnie is offline   Reply With Quote
Old 12-17-2004, 04:24 PM   #5
cooleyjb
Member#: 55727
#533 Spec Racer Ford
Better tires will do more for braking in a WRX than a BBK. A BBK will give you better feel and can usually resist brake fade longer but the point at which you tire lock-up is dictated by the tire usually.
cooleyjb is offline   Reply With Quote
Old 12-17-2004, 06:10 PM   #6
mistaboosta
Member#: 68722
I got the euro spec WRX and it has 17 inches on it. Here is a pic. of the stock rims of my car :
Guys better tires or whatever you say, I know how my car brakes and I felt how his car brakes. The difference is as huge as between a rabbit and a plane. We are both using the same tires btw. currently I have the stock 4 pot Subaru brakes and they just suck. I would appriciate if anyone knows about these BBK kits would fit into my rims or not...
Thanks indeed..
Old 12-17-2004, 09:10 PM   #7
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Edit: Nevermind--just read your other threads. Sorry to have wasted my time responding.
Jon Bogert is offline   Reply With Quote
Old 12-18-2004, 03:30 AM   #8
TWRRACING
Vendor
Member#: 39325
Our 310mm or 332mm brake kit will fit into those rims. Either our 6 piston or 4 piston setup will work. Does your friend also have the 2 piston rear Brembos, or just the fronts?
Have a look on our site:
www.twrracing.com
btw, I think StopTech uses a 28mm thick rotor.
Jerry
TWRRACING is offline   Reply With Quote
Old 12-18-2004, 05:26 AM   #9
mistaboosta
Member#: 68722
He's got the rear 2 piston Brembos either. does it make a big difference ?
Old 12-18-2004, 10:05 AM   #10
TWRRACING
Vendor
Member#: 39325
If you track the car, the rears make a BIG difference. Street driving makes a significant difference.
Old 12-19-2004, 01:12 AM   #11
srf
Member#: 50646
2004 WRX STi
Java Black
You can download a template from Stoptech's web site to see if they'll fit your rims. Also if the rims will fit STi Brembos, the Stoptechs would fit fine.
srf is offline   Reply With Quote
Old 12-19-2004, 01:18 AM   #12
srf
Member#: 50646
2004 WRX STi
Java Black
BTW looks like the Stoptech rotors are 28mm or 32mm not 22mm...
Just seeing if anyone is interested in stock WRX rims no tires AcorNNutZ Private 'For Sale' Classifieds 7 02-22-2006 11:16 PM
Black 03 wrx w/ FN01R-C's and Stoptech bbk slickvic Member's Car Gallery 34 02-14-2005 08:39 PM
FS: Rims and Stoptech BBK jetfan8178 Tri-State Area Forum 2 07-29-2004 01:04 PM
What the differnet between rotora and stoptech brake? FryRice Brakes, Steering & Suspension 3 11-23-2003 01:46 PM
Gauging Interest in stock WRX rims/tires Mr. Rogers Tri-State Area Forum 9 10-23-2002 08:24 PM
