Closed Thread
Old 12-17-2004, 10:19 AM   #1
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Default ABS Diagnsotics
How do I pull trouble codes from my 1999 Subaru Impreza for my ABS system. Also, after viewing the codes via the ABS dashboard light, how do I turn off the light.
Ramon_12345 is offline
Old 12-17-2004, 11:46 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There's a procedure in the FSM, it involves plugging the diagnostic connectors together and reading the codes through flashes of the ABS light. I don't have the '99 FSM so I don't know if the procedure has changed, it's probably the same or similar to the newer cars. You can download the manual from the Subaru tech site.
And, I'm locking this since I see you crossposted here and in Maintenance. More appropriate over there anyway.
Mulder is offline
Closed Thread
sti lip or abs plastic wrx lip and abs plastic side skirts...painted wrb is a plus NJ M32WRXin3seconds Private 'Wanted' Classifieds 1 08-24-2003 05:17 PM
Difference between ABS and non ABS Brake Lines? AKGC8 Brakes, Steering & Suspension 1 12-30-2002 09:24 AM
ABS gurus- I have a question about messed up ABS edkwon Brakes, Steering & Suspension 4 11-01-2002 05:00 AM
ABS on Non-ABS car mhj Brakes, Steering & Suspension 4 02-13-2001 09:41 PM
Gravel roads - ABS or no ABS? 8Complex General Forum Archive 7 06-20-2000 09:35 PM
