Old 12-17-2004, 11:57 AM   #1
ronf
Member#: 51034
03 WRX, 02Forester
Default Apexi TT A/F accurate ??
Installed Apexi with only TT function.
Is it worthwhile to tap the ECU for A/F reading ? If yes what pin # to tap for 03 WRX.
searched with different # results.
ronf is offline   Reply With Quote
Old 12-17-2004, 12:05 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No, they tap the rear 02 which is the only place you can use. Not accurate at all.
Old 12-17-2004, 12:29 PM   #3
ejh25
Member#: 65267
Shouldn't it be the front O2. Regardless, the readings you get from either the rear or front O2 sensors are absolutely worthless for tuning. The front O2 sensor is a narrow band O2 sensor. It will only read as rich as 12:1 AFR. Not nearly rich enough to tune high load, high rpm zones. You shouldn't even bother with it. Get a real WBO2.
ejh25 is offline   Reply With Quote
Old 12-17-2004, 12:56 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well the front 02 is not a conventional narrowband, nor is it a full-range wideband. So call it a "semi-wideband". Anyway it does not produce a standard 0-1V signal that can be tapped, so any tap-in type gauge will use the rear 02.
Old 12-17-2004, 12:59 PM   #5
ejh25
Member#: 65267
Thank you for the clarification.
WTT:CA:turboxs bov for Blitz bov/apexi TT for blitz FATT TT crashtest sonny Private 'For Sale' Classifieds 11 05-14-2005 11:26 PM
Apexi Avc-r, Apexi TT On Sales . In Stock!! Ready To Ship!! EAuto Engine/Power/Exhaust 0 08-13-2004 07:00 PM
APEXi tt / Greddy tt in stock EAuto Interior/Dressup/Audio & Security 2 06-21-2004 09:03 PM
Fore Sale Greaddy Gauages, Apexi TT, Apexi Grounding Kit mrtrex Private 'For Sale' Classifieds 16 06-16-2004 04:30 AM
Blitz DCC TT or Apexi TT Alfa Electrical & Lighting 4 04-23-2003 12:54 AM
