Old 12-17-2004, 02:20 PM   #1
SilvaRex
Member#: 36225
2006 STi
Default Starter Problem
Ok heres my deal ... Ive been gone for a while and my car has just been sitting in my garage ... I get home, ready to start my car up and nothing. I figured it was just the battery, so I charged that sucker ... Today, I get into my car, battery working, because all of the electrical stuff works, however, when I try and turn the car over, it doesnt. All I hear is like a clicking sounds over and over again. Does anyone know what this sound means??? And what can I do to fix it ....
thanks alot ... James
SilvaRex is offline   Reply With Quote
Old 12-17-2004, 02:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your battery may still be the culprit. It takes a lot more juice to crank the engine than to operate lights and accessories, so a weak battery would easily turn the lights on but may not be able to start the car. Once they've gone completely dead, they sometimes don't have all their capacity any more. Also, how did you charge it and did you have any way of checking its state of charge? Assuming you have the stock battery with removable caps, a cheap battery hydrometer from the parts store is very useful for measuring the charge in the individual cells. You might have one cell that's NG, or it may just need more charging. Also check the water level and add some if it's low, then charge it again. A cell with a much lower water level than the rest indicates a possible short in that cell.
Ultimately, you may need a new battery. The stock one has a relatively low capacity to begin with and isn't worth messing with after it's been run down a time or two.
Old 12-17-2004, 05:28 PM   #3
SilvaRex
Member#: 36225
2006 STi
Hey Mulder,
Thanks for the response ... Im going to use your advice and go check it out. Figuring the battery is 3 yrs old already, Im prob just going to buy a new one anyways ...
Thanks again,
James
Starter problems turns into locked up engine problem Minnesota1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-05-2007 06:03 PM
starter problems aschnell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2003 09:33 PM
('93-'01) '98 obs starter problem geepondy Impreza Forum 2 07-01-2003 05:51 PM
Starter problem 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 10:30 AM
Starter Problem darkangelgrafix Warranty Issues & SOA Problems 3 09-18-2002 09:28 AM
