Old 12-17-2004, 09:22 PM   #1
the mike
Member#: 30926
2003 MBP
Sedan
Default Rear disk conversion/diff conversion
So I recently picked up a 93 1.8L that already has had a 2.2 conversion done to it. This is fine for my purposes. What I can't stand is rear drum brakes.
I did a search and came up with no definate answers.
My question to you is...
What are my options for a rear disk brake conversion?
If someone could point me to a page that has ring gear ratio's for different models(or where in the VIN/car to look).
What I would ideally like to do is swap in an R160 from a WRX and find out what front brake options I have as well.
So as of right now I:
1. Have no idea what rear is under the car now.
2. Have no idea what the gear ratio is.
3. Am unsure as to what disk conversion options I have.
Any help would be appreciated.
Thanks in advance,
mike
the mike is offline   Reply With Quote
Old 12-17-2004, 09:27 PM   #2
LaParka
Member#: 10272
1999 EJ257 RS
LaParka is offline   Reply With Quote
Old 12-17-2004, 10:41 PM   #3
the mike
Member#: 30926
2003 MBP
Sedan
Thanks man, that answers question number 2. I have a 3.90 rear end.
It looks like I am looking toward a 2002-2003 TS or OBS for the correct ratio gears. Now to find out what the code for the rear in my car is(R160 for example) and to find out the feasibility of the TS/OBS rear swap.
As an aside, this car was bought solely for the ability to run hard on dirt.
I have the EVO for tarmac runs, the Suby is a rally project so I am looking to upgrade to the newest parts I can find. Like I said, rear disks with an adjustible proportioning valve would be nice.
mike
edit. Just saw that you added another link. There is a lot of good stuff in those two pages. Thanks.
Old 12-19-2004, 12:26 AM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
All 2.2l L's with manual tranny have 3.90 gears.
You probably do not need an adjustible proportioning valve. Most rear disc conversions are fine without it, but some people get better results with an SVX master cylinder.
Any rear disc set up will work except the STi 2 pots. Try to source the whole deal all at once from ebrake cable to whole knuckles and lateral links. It will make your life much easier.
linsavy is offline   Reply With Quote
Old 12-19-2004, 03:05 AM   #5
the mike
Member#: 30926
2003 MBP
Sedan
I am actually going to try to source a complete TS differential assembly to make things easier. We'll see what comes up first.
Old 12-19-2004, 09:50 AM   #6
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Adjustable proportional valve is available at www.summitracing.com
part number WIL-260-8420
wrx plus is offline   Reply With Quote
Rear Disk brake conversion 2000 impreza. overdrivex Brakes, Steering & Suspension 1 08-20-2009 05:04 AM
WTB: Rear disk conversion parts. ChrisRT NWIC Private Classifieds 7 07-27-2009 12:26 AM
Rear Disk Conversion!! Excellent for L's with rear drums! sidekickawd 1993 - 2001 Impreza Specific Parts 3 06-18-2009 08:48 AM
FS/Kent, WA/rear disk conversion ckcadavona NWIC Private Classifieds 6 02-04-2009 08:41 PM
GC Rear Disk Brake Conversion $200 - Northwest theonlygreat Suspension/Brakes/Handling 4 12-19-2006 10:44 PM
