Old 12-18-2004, 09:10 AM   #1
Blue_dragon
Member#: 43580
2004 Impreza WRX
Default Deep Cycle Batteries
Is anyone able to get a yellow top optima battery in a newer WRX? (Mine is a 04) Without redoing the factory wires. Or any other deep cycle batteries will probably worked too.
Blue_dragon is offline   Reply With Quote
Old 12-18-2004, 09:15 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes. There is now a Group 35 Yellow Top available that is a direct drop-in replacement for your stock battery and will use the existing wires. You want the "D35" Yellow Top. Do NOT get the "universal" 75/25, it has the top posts in a different location and you will need a longer starter cable, same as the 75/35 Red Top.
Old 12-28-2004, 02:15 PM   #3
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Have you verified that the D35 fits. It looks like the terminals are a bit forward compared to the stock battery and the 35R redtop. I'm about to order one so I just want to make sure. Thanks!
This is the one I'm looking at
http://sites.eoi.com/folder14788/ind...314&product=16
mtb_dude is offline   Reply With Quote
Old 12-28-2004, 02:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Schematic drawing of the 35 Red top-
http://www.1st-optima-batteries.com/schema_35.asp
Schematic of D35 Yellow-
http://www.1st-optima-batteries.com/schema_D35.asp
The dimensions are identical. I don't see why it won't fit w/the factory cables.
Old 12-29-2004, 09:31 AM   #5
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Cool, thanks that pretty much solves that.
Old 12-29-2004, 10:46 PM   #6
gh32
Member#: 9594
2005 WRX
Before you pull the trigger, I noticed that the dimensions of the (red top) Group 35 and the (yellow top) D35 batteries are similar, but the arrangement of the posts are different.
Here's the red top: http://www.optimabatteries.com/publi...035_082304.pdf
And here's the yellow: http://www.optimabatteries.com/publi...D35_082104.pdf
If the pictures in the .pdfs are to be trusted, it would appear that the D35 yellow top wouldn't fit without modification of the existing wiring. If the illustration at 1st-optima-batteries.com is correct, however, then there's no problem.
Thoughts?
-George
gh32 is offline   Reply With Quote
Old 12-29-2004, 10:55 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Interesting, maybe that pic of the D35 isn't accurate? Unfortunately there is no way to tell without actually seeing one. I don't know the definitive answer.
Old 12-30-2004, 09:14 AM   #8
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
That's what was confusing me. The D35 looks like the posts are in the front and in the normal position rather than in the back and "reversed" in the Red Top 35R. Why isn't there a drop in yellow top for 35R cars!?!?
Old 12-30-2004, 09:20 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I think someone needs to call or email one of these dealers, and ask. One drawing says they're the same, and another pic says otherwise. Only one can be correct.
But, if the worst case turns out to be true and the post arrangement is similar to the 35/75, it can still be used. You'll just need to replace the starter cable like those of us with 35/75's had to do, it's not a big deal.
Old 01-06-2005, 05:57 AM   #10
DirgeNoir
Member#: 55160
2004 WRX
Did anyone find a final answer to this? Does Yellow D35 fit as easily as Red Group 35?
DirgeNoir is offline   Reply With Quote
Old 01-06-2005, 07:51 PM   #11
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
bump for an answer.
Costco in Canada is having a sale on the RED TOP 75/35 .....will this fit in an STi?
bezerk is offline   Reply With Quote
Old 01-06-2005, 08:00 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes but the 75/35 is the universal version and you will need a longer starter cable.
Old 01-06-2005, 09:28 PM   #13
bezerk
Member#: 44809
2008 BMW M3
thank you so much for the info.
Old 01-06-2005, 09:38 PM   #14
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
BTW, according to TNA-Sports sales, the D35 is indeed the exact match to the Red Top 35. Optimas picture of the D35 is incorrect.
Old 01-07-2005, 04:08 AM   #15
949
Member#: 58906
why not call optima?
its a free call i believe. i called them last time. i learned alot from the lady that answered the phone.
* by the way for all you who want the best of both the red top and yellow top. basically she gave me the inside tip. so i asked her what is the trick? well the red is great for those who do the start up and who want the deep cycle for long use of stereo systems the yellow is best. but the blue top is the best of both worlds. now i dont remember exactly which one is the one you will need so you will have to ask optima again but there are a difference between the grey and dark grey bottom with blue top. i also believe the blue top costs more too. and yes i know its originally for marine but it should work for our 12v cars too. again you will need to call optima to verify the correct one. i guess cause the boats need a good start up and also for long runs as well cause your in the ocean. but there it is. just what i heard im not an expert so youll need to ver all this for yourself.
oh and they are water proof too!
949 is offline   Reply With Quote
Optima Yellow top Group 35 Deep cycle battery. GARGOYLE SCIC Private Classifieds 8 01-25-2010 05:24 PM
FS/FT: Exide/Rockford Fosgate Deep Cycle Car Battery (950 CCA) Drew dc5 MAIC Private Classifieds 1 10-18-2008 10:53 PM
Optima Deep Cycle Blue Top RicerJim Private 'For Sale' Classifieds 1 10-18-2005 09:05 PM
Optima deep cell of interstate battery? Sobelizard109 Electrical & Lighting 1 03-04-2003 04:35 PM
Battery options: Deep cycle??? Orbiter Car Audio, Video & Security 12 11-27-2000 07:23 AM
