Old 12-18-2004, 04:38 PM   #1
quazimoto
Member#: 70395
Default Adjusting Morettes
I was woundering which screw adjusted the up/down on the low beam?I see two adjusting screws one towards the outside with a clear plastic cap and one identical on the inside next to the high beam with out a cap.Its like this on both lights.
quazimoto is offline   Reply With Quote
Old 12-18-2004, 04:42 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Don't touch the ones with the caps, they are not used on the US version Morettes (they're for the leveling motor).
There are two adjusting screws for the low beams w/o caps. One moves the beam diagonally (simultaneously up/down and left/right), the other moves it vertically only. Adjust the diagonal one first to get the horizontal position correct, then adjust the vertical one.
Old 12-18-2004, 08:56 PM   #3
quazimoto
Member#: 70395
Which one is the verticle?I just need them to go up but i only see the one adjustment screw on the inside that doesn't have a cap.
Old 12-18-2004, 09:08 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There are two of them for the low beam. One is toward the outside of the light, the other inside. I don't remember off the top of my head which is the vertical and which is the diagonal.
Old 03-06-2014, 08:54 AM   #5
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I only see 1 philips head screw (bottom of the rubber boot) for doing the adjustment. Where is the other one?
shamrock 05 is offline   Reply With Quote
Old 03-11-2014, 07:14 AM   #6
shamrock 05
Member#: 120057
anyone?
Old 03-11-2014, 09:05 AM   #7
97OBLimited
Member#: 224432
1997 Outback Limited
2012 DGM Impreza Hatch
Just from looking at that picture, it looks like the screw you are referring to is the vertical. Just think about what moving the screw will do to the light. Why don't you just adjust it and see what happens?
97OBLimited is online now   Reply With Quote
Old 03-12-2014, 07:18 AM   #8
shamrock 05
Member#: 120057
Well it sucks because THAT screw is at the bottom of the light....what a fun PITA that will be
Old 03-12-2014, 06:55 PM   #9
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I dont know about the morrettes but sometimes the adjusters are hidden under a rubber cap making them harder to find.
frederik is offline   Reply With Quote
Old 03-24-2014, 05:09 PM   #10
quazimoto
Member#: 70395
The other adjuster screw the black plastic hex one with the flathead slot at the top of the light. It's kinda off centered. Opposite of the capped off one.
Anyone used Sparco adjustable aluminum side mounts? Patrick Olsen Motorsports 3 07-07-2010 09:11 AM
adjusting Morettes? Se3n Electrical & Lighting 4 03-24-2005 07:48 PM
How do I adjust Morettes? Orson Electrical & Lighting 8 02-20-2003 08:52 AM
Adjusting bolt for Morettes RallyX13 Alaskan Impreza Club Forum -- AKIC 1 09-12-2002 01:33 AM
