Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 12-18-2004, 08:47 PM   #1
WRX_scott
Member#: 51458
2003 WRB WRX 04 Conv
2.5L/Hydra/6spd/FMIC
Default Drive ability issues, battery related?
Lately my car has been driving weird. It pulls hard from 3K-4K then doesnt pull hard, then pulls hard again at 5K again. But once I resett the ECU it goes away. Could these be cause of a electrical issue related to the battery? Reason I ask about the battery, I have heard the stock battery sucks and dies out. Could this be the issue? I want to replace the stock battery anyways. What would you recommend, Optima?
WRX_scott is offline   Reply With Quote
Old 12-18-2004, 08:58 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your driveability issues are unlikely to be battery-related. If the battery is weak you'll notice slow cranking. If you want to check the overall health of your electrical system you can put a voltmeter across the battery and check it with the engine off (should be 12.5V) and running (should be 13.5-14.5V). Sometimes if diodes in the alternator fail the voltage may still appear normal but the alternator's output will be "dirty" and can cause unusual electrical problems. Only a shop with the proper equipment will be able to diagnose this type of condition.
If an ECU reset temporarily makes the car run better, this indicates that something may be causing the ECU to retard timing, and the reset returns the "learned" values to their defaults until you drive for a while. Bad gas is one possible cause of this.
Turn Signal issue, mod related? idmantis Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-03-2010 03:09 PM
Group N Engine Mount Fitment Issues...NA related... doubledribble Normally Aspirated Powertrain 7 01-08-2009 06:54 PM
APS tsr70 overheating issues!! fitment related! DJIMPREZA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-02-2008 12:24 PM
Clicking noise, battery related MaxPostal Electrical & Lighting 1 05-20-2007 09:41 PM
EJ18 issues... MAS related? Sephro Normally Aspirated Powertrain 4 02-03-2005 02:35 AM
